vacuum hoses
vacuum hoses
...hi there...I recently put back my 1969 350 4bbl in my 1951 ClubCoupe...I attached all vacuum hoses in the places they have been before and have been there when I got the car, but I donīt know if this is correct...can anyone tell?:
I refer to my picture...carb is edelbrock:
Upper right (small) hose to lower connection at the thermal switch
Middle right (bigger) hose to valve-cover
Lower right (small) hose to the modulator at the TH400
Upper thermal switch to vacuum advance at distributor
Thank you...
Thank you...
![](http://home.arcor.de/t.kottmann/mix/2012-05-08-olds-01.jpg)
Thatīs right, no power brakes...
...so I should get me 2 connectors I can screw into the manifold and attach the hoses directly (there are some blind bolts)...that would also mean, I have to close the 2 connctors at the carb...and I should buy a plug for the TVS-hole...
Thank you
Thank you
