tornado 403 firing order?
Old Jun 17, 2014 | 02:31 PM
WendellB's Avatar
Can anyone help me with firing order for 1978 Toronado 403. I am stranded!
Old Jun 17, 2014 | 02:58 PM
1-8-4-3-6-5-7-2
Just like the cast numbers on top of the intake manifold say.
And don't forget that the distributor turns counterclockwise.
Old Jun 17, 2014 | 03:11 PM
Old Jun 17, 2014 | 07:20 PM
WendellB's Avatar
Thanks! So my wires are correct but my engine is not performing above 35 mph and the secondary buttery are not opening to give full throttle. Every thing worked fine before so there seems to be a prob!em with throttle linkage!! Any suggestions?
Old Jun 17, 2014 | 07:23 PM
What did you do to it?
Old Jun 17, 2014 | 07:47 PM
Everything worked fine before what?
Old Jun 17, 2014 | 07:49 PM
Octania's Avatar
There is generally a small link that prevents the secondary buttery from opening if the choke is not all the way open. Maybe the choke is not adjusted or the link to the secondary air valve is on the wrong side of the pulloff arm.
You could have a helper depress the pedal and hold it down, then see if you can open the carb more by hand- if you cannot open it more by hand, then the gas pedal is doing what it should. Perhaps the timing has problems. What year Toro? Oh I see a 403 therefore 77-79. 1977 has crank triggered ignition which might conceivably cause such an issue.
I suggest you relate more details, like what was done [fixed?] just "before" this started.
Old Jun 17, 2014 | 08:04 PM
WendellB's Avatar
I had it smogged yesterday but it failed for what seemed a small miss so I replaced the spark plugs and wires. Later I noticed a manifold inlet that was left uncovered and thinking it was an oversight by the tech I got a cover for it but it did not solve my problem!
Old Jun 18, 2014 | 02:08 AM
nsnarsk65cutlass's Avatar
Manifold inlet uncovered,ya vacumn leak will fail a tailpipe smog test as the HCs will be high.
Old Jun 18, 2014 | 03:05 AM
rocketraider's Avatar
Oldsdruid
There's some difference on 78 Toronado engines but I can't remember exactly what. Those cars had the genesis of CCC electronic engine controls and some things were "different".
See if wildaboutcars has a link to the 78 shop book.
Old Jun 18, 2014 | 04:57 AM
s i 442's Avatar
Oldsmobile enthusiast
I noticed you posted this in the "big block" forum.
Its a small block for future posting questions.
Old Jun 18, 2014 | 07:02 AM
How do you know that? If you are simply revving the engine in park and looking at the carb, you will NOT see the secondary air valves open much. They are controlled by load, not the throttle. And FYI, you can't see the secondary throttle plates because those are on the bottom of the carb. Also, the 403 is a small block, so I've moved your thread.
Actually, Glenn, you're thinking of the MISAR crank-trigger ignition system, which is not really related to the CCC system other than possibly the software to do the ignition advance in the computer.
Old Jun 18, 2014 | 09:19 AM
WendellB's Avatar
Thanks Joe and friends! So my assumption of the secondary butterflies not opening up may be wrong. From all the input maybe it needs a tune up? Not sure what the tech did and I can not find what the spare inlet is for on the manifold. Before I go to a shop it maybe the spark plug gap?
Old Jun 20, 2014 | 10:10 PM
WendellB's Avatar
Thanks again for everyones help it was appreciated. But I am a bit embarrassed since the problem was simply my fuel filter. However after havingthe sending units replaced by a shop in town it did not dawn on me he did not check that before telling me I needed sending units for my fuel tanks!
So the 403 is a small block? This engine looks like a big bock not like a Pontiac 400. Also, I was trying to cross some busy traffic on Pacheco Pass and lit my tires all the way across intersection in my 10000 lb Royale! It must have been the blender!
Old Jun 21, 2014 | 05:24 AM
s i 442's Avatar
Yes its a small block, only a Pontiac engine looks like a Pontiac engine.
Old Jun 21, 2014 | 11:28 AM
uhh, check that again. The only Royale's were Delta 88's and none of them weighed anywhere close to that. Heaviest I can find recorded is around 4400 lbs and that's as a vert. Your suspension would have issues with you if it weighed 10K lbs.
Old Jun 21, 2014 | 07:48 PM
WendellB's Avatar
AllanR, it is GMC Royal, RV. Front wheell drive Olds Toronado .
Last edited by WendellB; Jun 21, 2014 at 07:54 PM. Reason: miss spelled words because of my pad.
Old Jun 22, 2014 | 06:10 AM
Ah, GMC motorhome. Very cool. I thought 1977 was the last year for those?
Old Jun 22, 2014 | 10:17 AM
WendellB's Avatar
Hey Joe my registration says 1978, how ever The club says the plans and manufacturing site was bought. out and production continued for a few more years.
Old Jun 22, 2014 | 01:23 PM
Here ya go Joe. WendellB? My apologies. It didn't occur to me that you were talking about an RV.
Old Jun 23, 2014 | 05:26 AM
WendellB's Avatar
Yeah it comes complete with a built in ice blender and vacuum cleaner.
Old Jun 23, 2014 | 05:25 PM
m371961's Avatar
I was trying to figure out why a Toro needed 2 gas sending units.
Old Jun 23, 2014 | 05:55 PM
Smitty275's Avatar
Engine Builder
My '74 Delta 88 Royale crossed the scales at over 4500 with the engine & tranny removed.
burnout-dave
Oct 21, 2011 05:02 AM
69sAndrew
Oct 24, 2009 10:57 AM
72rocket
Dec 30, 2008 08:31 AM
monahans10
Mar 9, 2008 07:58 PM
oldcutty
Sep 14, 2006 09:20 PM
