timing marks
Old Nov 23, 2010 | 10:33 PM
dman0712's Avatar
timing marks
Timing just doesnt seem right on my 403. I found two different examples of the timing marks. I have found crank 12 cam 6 ( rotor pointing at cylinder #6)
crank 12 cam 6 rotor pointing at cylinder #1 (like chevy 350) So which is it? Also does piston have to be at TDC of compression or exhaust stroke? Intake is currently off so couldn't i just just spin it over until both valves fully close? Heres a link to a site forum where they decided the rotor pointed at #6: http://www.ls1lt1.com/forum/showthread.php?t=27823
Old Nov 24, 2010 | 05:13 AM
Rickman48's Avatar
I don't see the problem - install the timing chain and gears as pictured, button it up, start the car, set the timing, and drive away! Done!!
Shoud start aimed at number 1 - without a probem!
If you changed cam + lifters, make sure you've used the proper lube and used oil with zinc, so it doesn't 'wipe out'!
If you didn't change the cam, most 'pollution' cams were ground with as much as 10 degrees retard from the factory, back then.
A cheap and basically undetectable horsepower gain would be to buy a Cloyes timing set, and advance the cam the 6 degrees they allow.
I did it once a few years ago, and there was a definate 'seat of the pants' feel, but the old chain was bad!
And make sure you change the water pump, as every one I've done needed a pump soon thereafter!
Seems while out, the seal dries and cracks, and the $25 spent means you don't have to tear it down, again.
Old Nov 24, 2010 | 05:20 AM
380 Racer's Avatar
Best performance is obtained by degreeing in the cam to the manufacturers specs.
Old Nov 24, 2010 | 05:55 AM
cutlassefi's Avatar
X2 Nick.
The rotor will point to #6 when the crank gear is at 12 and the cam is at 6. The rotor will point to #1 when the crank gear is at 12 and the cam gear is at 12.
Rickman- I believe he has a roller cam, no break in needed. How would you know to advance it 6 degrees if you don't check it. Don't assume, check it.
Old Nov 24, 2010 | 09:04 AM
dman0712's Avatar
That answers my question and hopefully solves my problem. I have crank gear at 6 and cam gear at 12 and my rotor points at #1. I will point it at #6 and see what happens
Carshinebob
Sep 11, 2013 04:06 AM
bullet1
Sep 25, 2009 05:44 PM
Gbobby
Feb 4, 2009 06:31 AM
cisco88
Oct 17, 2008 07:12 PM
MIRADAMANia
Apr 22, 2008 01:00 AM
