timing 350 rocket
Old February 15th, 2011 | 03:17 PM
83calais's Avatar
timing 350 rocket
what are some good base timing numbers with the vacum advance and without on a practically stock 68 350? the cam is stock and so is the bottom end and it has number 5 heads and headers and an exhaust can i get a base idea
Old February 15th, 2011 | 04:35 PM
Rickman48's Avatar
There are so many variables with todays fuel and the older engines, I just time it by ear!
Put the gas in it you're going to run, [hopefully premium, with your compression]and drive about 25 miles. Loosen the distributor hold-down bolt 'til you can move the distributor with some pressure.
Advance it a little, and drive it like you stole it! Repeat until it pings, then back it off a little, until it stops.
Tighten the hold-down, adjust the idle, and you're done!
Did this with my suburban, mileage went to 18MPG and it'll run hot if I go from mid-range to regular fuel. [Wife forgot!!]
Old February 15th, 2011 | 04:47 PM
If you still have points make sure your dwell is @ 30 first. Setting timing to 10 - 12 degrees BTC would probably do it @ 1100rpm, then reduce rpm back to 800 for curb idle. Then set your air/fuel mixture. The timing should not be set with the vacuum advance connected.
Old February 16th, 2011 | 07:22 AM
83calais's Avatar
thanks for the response and yes we are running premium and yea this is a father son project my dad likes to do it by ear i was just trying to get a baseline number
Old February 16th, 2011 | 07:24 AM
83calais's Avatar
thanks for the response but it is converted to hei and our idle currently is 1100 but anything lower than that and she likes to die is that normal i mean we havent timed it yet but when you start her she starts on the first revolution and runs pretty well but below 1000 rpms she doesnt like to stay running all the time
Old February 16th, 2011 | 07:35 AM
Check to insure the resitor wire was removed when it was converted. Make sure your choke is not sticking after it warms up. Hook up a tach and adjust your air/ fuel mixture for the highest RPM and then reset your curb idle speed.
Old February 16th, 2011 | 09:35 AM
83calais's Avatar
well we timed it to 12 btc because anything else and she ran so rough but now she runs smooth although the idle feels like there may be a cam we really dont know what was done to the block before we owned it and we have adjusted our air fuel and she is running smooth the funny thing is in park she runs at 1100 and in drive she runs smooth at anywhere from 900-1000 so id say shes running pretty good.
now our trans we got from a guy that swore it was rebuilt in a trade and we think it is shifting fine because if it wasnt we wouldnt be able to hit 55 mph without winding the motor out alot correct? because if it is shifting its shifting so smoothly we can barely feel it
Old February 16th, 2011 | 02:13 PM
Glad to hear your engine is running smooth now. Check for vacuum leaks and see if you can get the idle down below 1000 with the a/c on. Good deal on the trans!!!!
Old August 29th, 2012 | 12:50 AM
RonzBoyz4's Avatar
68 350 in a 1980 Cutlass Supreme with a turbo 400
Timing -
I started off at 14°, then to 16° back down to 12°.
Team, It feels like something is holding it back until I get to 2500-3000 RPM. Then it takes off, like changing gears.
I want that on takeoff sooner.
Thoughts?
"Rickman48" noted:
This is the direction I plan to go.
"83calais"
rough idle, like a cam, me too! I do not have a cam.
I had rough idle. So I rebuilt the carb, 17058230.
Still, one of my idle screws, passenger side, when I adjust it, does not make a difference to the motor. The drivers side, when turning, does. Example, if I turn it in the motor will die.
I plan to take the carb apart and see where the blockage is.
Thoughts?
Old August 29th, 2012 | 07:58 PM
olds 307 and 403's Avatar
Out of Line, Everytime😉
If you have an advance light, time for 36 total. One of my HEI's needed 12 initial, the other 23 initial to hit 36. The quickest the curves would come in, just over 3000 rpm with the lightest springs.
Old August 30th, 2012 | 08:18 AM
RonzBoyz4's Avatar
I am trying to follow....
1. Normal operating temperature
2. Plug distributor vacuum (corrected)
3. Set timing to 14° + - at 1000 RPM
4. Advanced timing light, set it to 36°
5. Slowly rev up motor to 2500-3000 RPMs
6. The light should light on “0” on the timing mark
Correct?
Old August 30th, 2012 | 08:30 AM
2. Plug trans vac
3. Set timing to 14° + - at 1000 RPM[
6. The light should light on “0” on the timing mark just as the engine passes about 3,000 RPM, and stay there as you rev higher.
Correct?
You don't plug the transmission vacuum, you disconnect and plug the distributor vacuum.
Old August 30th, 2012 | 09:12 AM
2. Plug trans vac - as Eric said - plug the vacuum advance line.
3. Set timing to 14° + - at 1000 RPM - disregard this step because step 4 will set this!
4. Advanced timing light, set it to 36° - 34-36*
5. Slowly rev up motor to 2500-3000 RPMs - double check at 3500 RPM
Correct?
Old October 22nd, 2023 | 03:03 PM
Fonz's Avatar
How does it shift under full throttle ? you suerely should Feel it. if it had a shift kit, you would KNOW IT. shifting too smooth.... whats the fluid look like?? should be transparent pink, and toutch of brown, it may be slipping . been sitting that long, maybe sticky valve body.
Old October 22nd, 2023 | 03:41 PM
The OP's have probably figured this out over 10 years ago.
Old October 22nd, 2023 | 05:13 PM
Rocket Renegade!
Or not and the car's spent the decade under a tarp in the backyard, covered in leaves.
Old October 22nd, 2023 | 05:21 PM
DOOR #1
DOOR #2
I pick what's behind DOOR #1.
Old October 22nd, 2023 | 05:41 PM
Fonz's Avatar
I remember 22 years ago when the engine was torn down I had to replace 2 of the rocker arm bridges (aluminum, new are steel), but the NOISE this thing is making, ( and I can FEEL IT with my hand on the carb,)that generally preceeds it shutting down. then it will start right up and run like new ! (stethoscope picks up nothing). it is now has the timeing reset to 12 degrees ( USING" ORIGINAL MARK" ON BALANCER), NO DIFFERENCE WHATSOEVER. I took a NEW 600 Edelbrock off of one of my other projects, installed it, started right up idled beautiful, then started doing the same crap, the noise and Breaking up -- 5 psi fuel at all times, 17 vacuum, 12 degrees before top dead center, idles smooth at 900, .mech adv not sticking, vac adv working properly , used a smoke can to check for vacuum leaks, ...............................................I really do not want to be tearing this thing down , but that "rapping" is scaring me !!
Old October 22nd, 2023 | 05:47 PM
I don't believe you realize you are not in the correct thread discussion to be talking about the issues on your vehicle?
Old October 22nd, 2023 | 07:45 PM
Rocket Renegade!
DOOR #1
DOOR #2
Optimist.
Old November 1st, 2023 | 12:13 PM
Fonz's Avatar
OK, Where should it be ???
Old November 1st, 2023 | 05:51 PM
Rocket Renegade!
Probably in the thread you started.
Old November 2nd, 2023 | 12:36 AM
Fonz's Avatar
OK, had not realized I added on to someone else thread. sorry about that. how do I locate my original post ? Thanks
Old November 2nd, 2023 | 03:14 AM
I copied the post (above) verbatim & pasted it into the original thread over one week ago. That post is located here >>>>> Post #102
in your original post located here >>>>> 350 rocket making me crazy
Old November 2nd, 2023 | 07:39 AM
Rocket Renegade!
Norm makes it easy for you, but in the future you can just use the drop-down menu under your screen name in the upper right-hand corner. Find "My Posts," click on it and it will list all the entries you've posted, starting with the most recent.
Old November 2nd, 2023 | 08:47 AM
Fonz's Avatar
Thank YOU, WILL TRY THAT.
Old June 7th, 2024 | 04:16 PM
Fonz's Avatar
no more noise, but still runs badly
tgilligan
August 11th, 2017 07:54 PM
Supernaut72
16
September 1st, 2016 01:38 PM
1970442
March 8th, 2016 08:42 PM
young old car guy
June 26th, 2012 10:35 AM
67Olds442X2
September 18th, 2011 02:39 PM
