Thin head gaskets for 350 availabilty?
Old Oct 14, 2021 | 09:43 AM
hystat's Avatar
I'm wondering if the .028 gaskets or other similar thin gasket available. Also, I'm wondering how I might check these #7 heads I bought to see if they have been milled. Are there dimensions I can measure?
Old Oct 14, 2021 | 11:28 AM
v8al's Avatar
Registered Olds Owner
Check out Cometic MLS Head Gaskets they are available in various thickness including .027
https://www.summitracing.com/parts/c...ake/oldsmobile
They are pricey at $94 each.
I don't know a dimension you can use to check if they have been milled. CC'ing the combustion chambers will give you one of the numbers to calculate the compression ratio.
If you have excel download a compression ratio calculator like the one found on this page: https://www.us.mahle.com/en/motorspo...h-information/
Old Oct 14, 2021 | 12:47 PM
Measure the combustion chamber volume. This will give you exact data that can be used to calculate the compression ratio to determine the appropriate piston dish and head gasket to use.
Old Oct 14, 2021 | 05:04 PM
olds 307 and 403's Avatar
Out of Line, Everytime😉
Unfortunately the cheaper .028" are no longer available. As said, measure the chamber. A piece of plexiglass, vaseline and a syringe. I used coloured washer fluid, easier to see.
Old Oct 14, 2021 | 06:12 PM
BillK's Avatar
Post a picture of the deck surface of the heads. I should be able to tell you if they have been milled.
Old Oct 14, 2021 | 07:05 PM
I was thinking, what if it's obvious that either 1) the heads have been milled, or 2) the heads have not been milled.
What does this do for you? Either way you don't know the combustion chamber volume since the volumes varied due to manufacturing tolerances, so the next step would be to cc the chambers to determine the volume.
Old Oct 16, 2021 | 04:55 PM
OLDSter Ralph's Avatar
Correct !!!!
Old Oct 19, 2021 | 08:54 AM
brownbomber77's Avatar
I remember Smitty used to offer .011" ones but can't get a hold of him on Facebook. Did he sell his inventory or drawings to someone?
mother$hip89
May 29, 2019 07:46 PM
my71olds
Aug 14, 2013 05:49 PM
jag1886
Aug 15, 2011 05:29 AM
dsolomon
Mar 23, 2011 11:08 AM
1969cutlazz
May 16, 2010 08:07 PM
