Surging at wide open throttle
Old May 27, 2013 | 02:55 PM
Redog's Avatar
Car runs great, but today and only at WOT going into 3rd and 4th, it won't go faster than 50 and is surging. Go stop go stop and it inches above 50. If I don't floor it, it's fine. I did notice some wires that got burnt, but it didn't look like they where burned thru, otherwise I would have replaced the wire sections.
Car ran awesome yesterday! Fastest 1/4 mile times ever!
1985 delta 88 with the 307
Old May 27, 2013 | 03:08 PM
Erinyes's Avatar
Fuel pump or filter?
Old May 27, 2013 | 03:22 PM
What air cleaner is on there? I've found that when people changed it or flipped the cover over these issues arise.
I will also x2 on the fuel filter or pump.
And I will also add a catalytic converter to the mix.
Old May 27, 2013 | 03:42 PM
Redog's Avatar
I was thinking fuel pump the filter was changed about 2 years / 5000 miles ago
Old May 27, 2013 | 03:44 PM
Redog's Avatar
I have an 80's 442 dual snorkel air cleaner on it with a K&N stock size filter. Been on there since February
Old May 27, 2013 | 05:02 PM
tru-blue 442's Avatar
Old School Olds
Sound like the carb is starving
for fuel possibly?
Old May 27, 2013 | 05:05 PM
TripDeuces's Avatar
My 88 truck did this, was the fuel pump
Erinyes's Avatar
I had a stock paper filter that hardened into rock, basically, after three years and less than 1000 miles. It's worth checking.
Old May 27, 2013 | 07:53 PM
Redog's Avatar
Tru Blu, sounds like a good place to start. I broke the steal fuel line and replaced it with a rubber one, maybe it's kinked somewhere
Old May 28, 2013 | 02:16 PM
Is it a CC engine? I remember turning the air cleaner lid over on a 305 sbc caused the same symptoms you describe. Just saying.
Old May 28, 2013 | 04:11 PM
Tedd Thompson's Avatar
I've had a catalytic converter do that on a furd f150, got to where it wouldn't pull a tiny hill. But it also sounds like it could be a fuel problem...Tedd
Old May 29, 2013 | 09:00 AM
Redog's Avatar
Fuel line, now fixed and car runs good!
Old May 29, 2013 | 09:13 AM
So what was the cause?
Old May 30, 2013 | 08:47 PM
Redog's Avatar
Fuel line was kinked pretty bad
Funkwagon455
Jun 1, 2014 09:49 AM
Redog
Jul 15, 2012 06:21 PM
jaymann
Oct 19, 2011 10:41 PM
The Stickman
Dec 4, 2008 11:36 AM
BArmand
Jul 16, 2008 06:59 PM
