stutter, hesitation, under load only
Old Jun 13, 2016 | 06:55 AM
455Eldorado's Avatar
Perhaps this will help someone out...
For months I experienced engine stutter when accelerating or under load. Felt like engine is running out of fuel. I first replaced the fuel pump, filter and since that didn't help tried with all sorts of jet/rod combos, different carb power piston springs...with some limited effect. Than I turned to ignition, since the symptom was also similar to ignition miss under load.
Changed spark plugs, tried different gaps, new cables, rotor&cap, module,....all but the HEI itself. Nothing helped. Idle was fine, so was cruise, although the vacuum gauge did show 1/2 inch rapid vibration at idle.
All that until I replaced the HEI distributor itself. Looks like either the magnet pole or reluctor coil can make it feel like fuel starvation at WOT...or light but annoying miss under load. It check's out OK with the ohm meter and it was new when installed...
Old Jun 13, 2016 | 07:31 AM
I'm assuming the hei straightened out your issue.
Old Jun 13, 2016 | 07:43 AM
The coil and the magnet was the only thing left to replace...but it was easier to put in another distributor. I assembled one from different parts I have, to make one used "Frankenstein" HEI distributor...just too see if it will make any difference. And it did. Since the magnet and the coil are only parts of the distributor that ware not replaced before I assume one of them created the problem . It runs like a dream now!
Old Jun 13, 2016 | 08:19 AM
The old addax that most carb problems are actually ignition issues still holds true.
jd25q
Jan 31, 2015 01:53 PM
56Holiday88
Nov 4, 2011 12:00 PM
defiant1
Aug 8, 2011 03:27 PM
61olds
Jul 12, 2011 01:51 PM
66ninetyeightls
Aug 23, 2010 12:24 AM
