stuck head?
stuck head?
trying to get the heads off the block, seems to be pretty stuck.. its a 350 the manifold was hard to get off as well but i just want to make sure theres no tricks im not aware of to get this thing off!
I dont even want to know.. haha but thank you for your replys man.. were learning over here, i figured it was just stuck on there from age but didnt want to end up screwing something up!
Make sure you get all 10 bolts. You might have only got the ones by the valve springs - there's also 5 down by the spark plugs.
Okay guys, i went a little deeper into the unknown and pulled the heads only to have coolant flood my garage as soon as i cracked the seal.. I know thats not right but what would cause this? blown head gasket? I turned the motor on and all 8 pistons move as they should. let me know what your thinking
thanks guys
thanks guys
Did you drain all the coolant before pulling the manifold off? If not, there's your answer.
Not really an issue if the engine isn't running, just be sure to change the oil BEFORE running the engine
![Wink](https://classicoldsmobile.com/forums/images/smilies/wink.gif)
its down to the block now, im not really trying to fix this 350 at the moment. Im just trying to find out whats wrong with it because i plan to rebuild it in the future.
I didnt see any thing that looked broken, lifters, valves/springs.. Cranked the motor and all pistons are working.is there anything els i should do or check?
the car had been knocking slightly for 2 days prior to this, then that knock turned into what sounded like the whole engine falling apart LOUD clanks that were in rythme with the motor and obviously got worse with any amount of gas.
I have a 455 block that i might as well start having built no sense in rebuilding a 350 whe i got a 455 in the same garage.. I look at the 350 taking a poop as gods way of saying "go faster" but id like to know what the hell happened to this thing!
thanks everyone
thanks everyone
You guys are aware that the block has a drain plug on each side, right? 9/16 wrench size, 1/4 NPT thread. Usually tight as hell, and blocked underneath with 30 yrs of crud.
Use a screwdriver to poke a hole in the crud after removing the plug- use impact if need be, and SIX POINT DRIVE TOOL in any event. Have drain can handy/ ready.
PS I have lots of nice pretty new drain plugs. Inquire at 517.449.04 three two.
Use a bit of sealer and tighten just hand snug to install.
That's what I was thinking at the start. More likely a connecting rod issue and/or spun bearings. Since the motor is this far apart, it just makes sense to pull it and check it out.
805? No, I won't laugh. I started tearing down a 455 last year and had all kinds of trouble. Problem was it wasn't a running engine. Turned out to have 2 monster cracks in the coolant jacket by the #7 cylinder. Turned into a boat anchor. But, like you I learn a lot as I go.
I'm at the stage where the compression in my 350 makes it a strong candidate for rebuild.
That still leaves the cylinders with green juice.
Ok heres a simple (caveman) way to check for a loose rod bearing if you got the heads off... turn the crank until the piston in the cylinder you want to check is headed back down into the hole. Now take a hammer handle and hit teh top of the piston.. if the bearing is bad, you should hear a pronounced "clunk" when the extra clearance from the loose bearing allows the rod to slam against the crank. If it's really bad, you will also see or feel the piston move. If that happens, stick a fork in it, it's done!
