Sport comp water temp and intake question
If that's a mechanical temp gauge, no it cannot be fixed (at least not easily or cost-effectively. Mechanical temp gauges use an expanding fluid stored in the sensing bulb to operate the gauge. It's not a wire, it's a very small tube and once it breaks the fluid leaks out. Get a new gauge.
Despite the electric sending unit in the intake, the "wire" in the photo above appears to be the tube for a mechanical gauge. Note the extremely thick plastic cover, which is typical of that used on mechanical gauges. Also, that would be VERY thick solid copper wire if it were, in fact, a wire. I've got $10 that says it isn't.
atkinsom
May 26th, 2013 05:52 PM
Emreozd
February 19th, 2012 06:27 AM
texasred
July 31st, 2007 10:18 AM
