Silvo-lite 1433
Old December 27th, 2010 | 09:48 PM
80_cutlass's Avatar
Silvo-lite 1433
Could this piston be used in a 350 olds?
STD. BORE SIZE
4.0938 / 104mm
COMP. HEIGHT
1.747
PIN DIAMETER
0.9898
offset
COMPRESSION RATIO(s)
9.6
sb
Old December 28th, 2010 | 06:27 AM
captjim's Avatar
Not without a lot of work.
Old December 28th, 2010 | 05:02 PM
64Rocket's Avatar
you will need different rods. You can offset grind the crank and use different rods.
Gene
Old December 29th, 2010 | 06:50 PM
80_cutlass's Avatar
Oh well. The machine work/rod cost will more than offset the purchase price of high compression pistons designed for the sbo in comparison to the price of the 396 pistons. (Just saw some of these on ebay for a bit over a 100 bucks.)
sb
dynamic63
April 21st, 2014 08:50 AM
FirstClass 383
August 6th, 2013 07:17 PM
Goldhawg
September 5th, 2012 04:19 AM
wmlewis
February 27th, 2012 09:26 PM
442Harv
Brakes/Hydraulic Systems
April 3rd, 2008 01:34 PM
