Silvo-lite 1433
Old Dec 27, 2010 | 08:48 PM
80_cutlass's Avatar
Silvo-lite 1433
Could this piston be used in a 350 olds?
STD. BORE SIZE
4.0938 / 104mm
COMP. HEIGHT
1.747
PIN DIAMETER
0.9898
offset
COMPRESSION RATIO(s)
9.6
sb
Old Dec 28, 2010 | 05:27 AM
captjim's Avatar
Not without a lot of work.
Old Dec 28, 2010 | 04:02 PM
64Rocket's Avatar
you will need different rods. You can offset grind the crank and use different rods.
Gene
Old Dec 29, 2010 | 05:50 PM
80_cutlass's Avatar
Oh well. The machine work/rod cost will more than offset the purchase price of high compression pistons designed for the sbo in comparison to the price of the 396 pistons. (Just saw some of these on ebay for a bit over a 100 bucks.)
sb
dynamic63
Apr 21, 2014 07:50 AM
FirstClass 383
Aug 6, 2013 06:17 PM
Goldhawg
Sep 5, 2012 03:19 AM
wmlewis
Feb 27, 2012 08:26 PM
442Harv
Brakes/Hydraulic Systems
Apr 3, 2008 12:34 PM
