Should I have my heads rebuilt?
As many of you know I've posted a few threads regarding my 54 olds 88 and some of the engine problems I've been experiencing. Here's a brief summary:
* Burns oil (light blue smoke at start-up and while running.)
* Motor starts OK when cold, oil pressure at around 30 pounds.
* After warmed up, motor wants to stall, especially when put in drive.
* Oil pressure drops to about 10 at idle after warmed up.
* Compression tests showed all cylinders around the 107-115 range.
* Leakdown tests had a lot of air escaping out the oil filler tube.
I know air out of the filler tube is supposed to indicate bad rings, but that doesn't jive with the compression readings I got. I've been told it could be valve guides and seals. I have checked for vacuum leaks and found none. I have put the old girl up for the season, and I'm planning on taking the heads off and having them re-done at a machine shop.
Is this the right course of action to be taking at this point? I have no plans on driving her until next year, so I have plenty of time to decide what to do.
Thanks!!
Thanks!!
Thanks!!
Thanks!!
The very simple test is to run a compression test dry (after warming the engine) then squirt a little oil in each cylinder and run it again. The oil serves to seal the rings, so if the compression raises significantly with the oil, you need rings. If not, you need the heads done.
I neglected to mention that I did do that on a couple of cylinders. There was no change.
brandon reynolds
April 10th, 2012 12:06 PM
