Which Sealant Do You Prefer?
Old May 16, 2012 | 10:25 AM
dephconn24's Avatar
Question Which Sealant Do You Prefer?
Got my "new" VCs from Allan R, thanks again.. and ive heard to use High Temp black RTV sealant when installing gaskets and I was curious what you guys use/prefer to use?
thanks in advance
Old May 16, 2012 | 10:38 AM
XMWZ001's Avatar
Permatex "The Right Stuff". The only way to go.
Old May 16, 2012 | 11:03 AM
CQR's Avatar
CQR
Here at the shop we use GM's grey sealant. Part # 12378521
Old May 16, 2012 | 11:18 AM
rustyroger's Avatar
'87 Delta 88 Royale
"Hylomar" over here.
Roger.
Old May 16, 2012 | 11:21 AM
J-(Chicago)'s Avatar
Seasoned beater pilot.
Permatex ULTRA GRAY. The others smell like crap and are too greasy. I like the parts to stick together and not slither all over the place. 10 times easier to scrape as well, because it doesn't booger up.
Old May 16, 2012 | 01:01 PM
dephconn24's Avatar
thnx guys.. ill check out what my autozone by me has.. most likely going to go with permatex then
never heard of hylomar though
Old May 16, 2012 | 01:07 PM
Stevec's Avatar
Honda-bond get it at any Honda auto dealer works awesome!
Old May 16, 2012 | 03:56 PM
jag1886's Avatar
I depends on the type of gaskets your are using.
Old May 16, 2012 | 06:54 PM
dephconn24's Avatar
i dont have any in mind atm.. which one would you recommend?
Old May 16, 2012 | 07:44 PM
4424me's Avatar
X2 on the permatex ultra grey, Awesome stuff!
Old May 16, 2012 | 09:17 PM
BILL DEMMER's Avatar
Just the facts...
permatex high-tack on vc gaskets.
bill
Old May 17, 2012 | 07:33 AM
rustyroger's Avatar
'87 Delta 88 Royale
That's because it's sold in the UK.
Roger.
Old May 17, 2012 | 03:35 PM
jag1886's Avatar
If you use a rubber gasket you can use a little High Tack to hold them in place on the cover while installing (technically you don't need sealer with rubber gaskets) if you use cork gaskets (I always do) you use a little black silicone on the cover side only put the gasket on the cover press in place let it sit for 15 minutes and install.
Old May 17, 2012 | 06:06 PM
dephconn24's Avatar
alright thnx.. i remember watching a video on installing VCs and they did basically just that
Old May 18, 2012 | 09:36 AM
mdd71's Avatar
The Right Stuff___-
Old May 18, 2012 | 09:45 AM
nonhog's Avatar
Registered car nut
wonder if its same supplier as Toyota FIPG? Amazing! Black RTV is like garbage next to this stuff.
Old May 19, 2012 | 07:42 AM
MX442's Avatar
The Right Stuff is a great permanent sealant, but... I wouldn't use it on Valve Covers. For the rubber style, high tack, gaskacinch, etc. to glue it to the cover. Then nothing between the gasket and the head.
But wait, there's more... For the price of $30, you can pick up a set of Felpro 1658 valve cover gaskets. No sealant necessary, and they last forever.
MDchanic
Apr 14, 2014 04:33 AM
Tedd Thompson
Feb 27, 2013 06:50 AM
ent72olds
Jan 5, 2013 11:40 AM
Blackpage
Paint
21
Dec 29, 2011 04:19 AM
dar83501
Dec 28, 2007 08:23 PM
