RR Heads
RR Heads
Okay for you big boy's here, the RR heads are they just for racing or can you use them on a performance engine that you play around with,go to the track, flip laps around town......
PS 77: It would be no worse than putting big block heads on a small block.
Hate to see you waste it LOL, 730 HP @7400 and 579 @5400. Here's a tech article for ya:
http://www.dragracingonline.com/tech...ldstech-1.html
It does 1.30-1.31 sixty foots. Running all out,it did run a 9.68 but we keep it down to win races running 9.90s low 10s. I guess it works......we won a championship last year.
Hey 380 are these diesel block's easy to come by or what where they in? do you use them because they are heavier? Also with those RR heads, what type of manifold do you have to use
The diesels came in early 80s Cutlasses. They were in other cars also but can't think of the others right now. We filled the block with a regular block filler (made it even stronger).
I'm afraid the only intake for it is theirs. Or get a sheet metal made for it. It isn't real bad tho for the ETs I run with one
Thanks for the article.Put alot of time and money into that engine
