RPM performer hood clearance '71
Old Jun 21, 2016 | 11:39 AM
rdtreur's Avatar
I want to run a RPM performer in my 1971 Cutlass but I want to make sure I got 6.5 inch clearance from the top of the intake to the hood.
I know that some of you guys run stock air filterhousings on top of there RPM's but I need to know that I got 6.5 inch clearance....
please let me know. Many thanks, Ramon
Old Jun 21, 2016 | 12:25 PM
Sounds like you need to make some measurements as that is the only way you will know how much clearance there is on YOUR vehicle.
Old Jun 22, 2016 | 07:51 PM
coppercutlass's Avatar
Chevy budget Olds powered
I run the rpm a half inch spacer A NON drop based air cleaner with a 3 inch open element air fileter and the wing nut just scrapes the hood barely. The drop base will significantly add clearance. I think the stock air cleaner hangs down a bit more that the typical open element bases but you will need an adapter on a holley.
Old Jun 22, 2016 | 08:30 PM
rdtreur's Avatar
Thanks for the info guys. Coppercutlasscan you measure your setup maybe ? The resone I ask, I want to use this setup on a rpm performer in a 71 cutlass:
It's a impco 425 mixer for running on propane.
dads72
Dec 10, 2015 08:25 AM
coldfire
Aug 20, 2013 04:06 PM
Tony72Cutlass'S'
Jul 12, 2011 05:29 AM
808olds
Sep 16, 2010 11:38 PM
mp71conv
Nov 18, 2008 03:57 AM
