Rough idle and stalling
Old May 22, 2017 | 10:15 AM
Amarion58's Avatar
I have 307 olds that idling rough and stall at the red lights. It idles fine when I partially close the chock but when I let the chock go it opens fully and start idling rough and stalls. I haven't tried anything yet but I'm thinking it's a problem with the chock
Old May 22, 2017 | 11:00 AM
If the choke if fully open when it warmed and closed when its cold then its operating properly. I'd check for vacuum leaks to start with.
Old May 22, 2017 | 12:01 PM
jaunty75's Avatar
I just went through this same thing with my '78 Toronado with a 403. I rebuilt the carburetor, but along the way, I replaced all vacuum hoses and put on a new EGR valve. A bad EGR valve can cause stalling at idle speeds.
My car now runs ok. To check choke operation, with a cold engine, remove the air cleaner and press the gas pedal to the floor to see that the choke plate closes. Assuming it does, start the car. The choke plate should almost immediately back off slightly (open slightly more) if the choke pull-off is working properly. As the engine warms, the choke plate should become fully vertical. This assumes the choke stove is properly connected and functioning properly so that engine heat is getting to the metal coil in the choke housing. If it does all of this, the choke is OK, and I would look for other possible sources.
Oldcutlass mentions vacuum leaks, and that can certainly be a cause. So can a stuck carburetor float or other problem in the carb that might cause flooding.
Old May 22, 2017 | 12:14 PM
Amarion58's Avatar
Well its not the chock then because it fully open when warm. Ill check the vacuum lines whenever I make home if it keeps starting. It just started this morning on my way to work so I haven't had a chance to check anything besides the chock
Old May 22, 2017 | 01:07 PM
Also if it started after recently getting gas it be water in the fuel.
Old May 22, 2017 | 02:10 PM
Let's start with basics.
What year 307? Is the factory CCC system still in place or have you changed anything? Are there any coded in the computer?
Old May 22, 2017 | 02:35 PM
jaunty75's Avatar
That's no fun!
Old May 22, 2017 | 04:32 PM
Amarion58's Avatar
Home now and found I had no antifreeze no oil or trans fluid. I think I been sabotaged lol.
Old May 22, 2017 | 05:12 PM
Amarion58's Avatar
Problem solved. My daddy said my timing chain skipped a tooth.
Old May 22, 2017 | 07:23 PM
That would not cause the loss of fluids...
Old May 22, 2017 | 07:56 PM
Cutlass Fan's Avatar
If partially closing the choke (not "chock" lol) improves the idle then you have developed a lean condition at idle. A vacuum leak is a definatle a possibility. You could also have a partially clogged idle circuit.
Old May 22, 2017 | 08:32 PM
Amarion58's Avatar
I really don't know I'm going on advice on what it could be. After I fill up the oil and antifreeze the carb started shooting fire out. If yal have any advice to offer I will gladly take before I tackle a timing chain and spocket. I thought it was bad gas at first because it was stall if unless I held the brake and gas. Then I got home and found no oil no trans fluid or antifreeze. I'm stuck and this is my daily driver. I'm really in need of help right bowl because this is my trans back and forward to work.
Old May 23, 2017 | 04:25 AM
I don't doubt there is a timing chain issue, but your neglecting normal maintenance will lead to failure also.
Old May 23, 2017 | 09:50 AM
Amarion58's Avatar
The no oil and water started yesterday while trying to limp home. The water is shot and the oil pressure switch was spitting oil everywhere. I keep it well maintenance. But on the other hand someone told me can set the distributor back one gear tooth and drive to my daddy shop to change the chain. Have anyone ever heard of there.
Old May 23, 2017 | 09:54 AM
Someone told you wrong. When a timing chain jumps a tooth it changes the mechanical valve timing with relation to the pistons. Moving the distributor changes the ignition timing as to when the spark plugs fire.
Old May 23, 2017 | 10:00 AM
Amarion58's Avatar
Thanks for the info I don't wasn't tear anything up. Guess I'm stuck doing it in my driveway.
Old May 23, 2017 | 10:13 AM
Does your car insurance provide towing coverage?
Old May 23, 2017 | 01:19 PM
Amarion58's Avatar
No roadside assistance
Old May 24, 2017 | 05:27 PM
Amarion58's Avatar
What the difference between single roller vs a double roller timing chain. Autozone say its best if i get the double but I'm only have a stock engine and don't think a double roller would make any difference in a stock 307 beside the cost of the kit
Gooner
Oct 7, 2013 12:43 PM
Skeeter Vaughn
Aug 11, 2012 01:52 PM
silverriff
Mar 21, 2010 10:12 AM
novice57
Jun 3, 2008 04:35 AM
UCF72Cutlass
May 31, 2008 07:09 PM
