403 Engine runs rough and dies at idle
Old Jul 25, 2012 | 08:54 PM
Skeeter Vaughn's Avatar
I'm having issues with the motor in my car. It's a 77' 403. It dies at an idle, shakes like it is missing and when you get it past idle it smoothes out and runs good. It sounds like it is running out of gas to me at an idle?. So far I had the carb rebuilt new throttle shafts and kit, vacuum lines, intake and valve cover gaskets, EGR valve, It has new plugs, wires and the rest of the goodies. It holds about 16 pounds of vacuum at a faster RPM. May be some of you all have had this problem before. Any input would be great. It has to be something simple, yet to well hidden for me. Thanks!
Old Jul 25, 2012 | 09:48 PM
Most obvious explanation is a vacuum leak.
Check around all of that new stuff you put on it - you may have a hose off.
Old Jul 25, 2012 | 11:30 PM
ah64pilot's Avatar
I agree. I spent $80 at an auto shop when I was 17 for the same problem with a 455. After fixing it I ask what they had done...found out they just put a rubber cap on a vacuum port I left open.
Check for something obvious, most of the time we just forget something.
Old Aug 9, 2012 | 07:42 PM
Smile
Found out my problem. Nothing to do with the intake or the vacuum. The carb had internal cracks and it was sucking air. I pulled off a carb from my parts car and had it built and it runs great now!! Problem solved!!
Old Aug 10, 2012 | 04:53 PM
Which is pretty much the definition of a vacuum leak...
Old Aug 11, 2012 | 11:38 AM
Yes it was a vacuum leak, just not in the usual places! Oh, and by the way, Where were you when I had the initial problem? Yet quick to point out the obvious?!!
Old Aug 11, 2012 | 01:52 PM
Olds_71_442's Avatar
I'm assuming he didn't answer before because he was thinking vacuum leak like everyone else.
tds
Aug 4, 2015 02:27 PM
aquabird
Oct 2, 2013 10:34 PM
stagreen
Aug 3, 2012 10:34 AM
deaddds
Ninety-Eight
Jul 17, 2011 04:42 AM
Aedwards
Aug 27, 2010 02:44 AM
