rocker bridges - 1967 330
Old May 14, 2010 | 09:52 PM
wjustinmartin's Avatar
I was speaking with an old salty mechanic this afternoon regarding my tapping 1967 330. He suggested that it was the bridges on the rocker arms. Does that sound plausible or does anyone have any experience with that part failing?
Old May 15, 2010 | 04:38 AM
jensenracing77's Avatar
i have had one brake several years ago. it was rattling pretty good. by the time i got home it had bent a pushrod also.
Old May 15, 2010 | 07:52 AM
J-(Chicago)'s Avatar
Seasoned beater pilot.
Those are definitely a weak link. Melling makes steel replacements so you can get rid of your aluminum ones.
Old May 15, 2010 | 10:02 AM
svnt442's Avatar
To clarify...... they are a 3 piece unit as opposed to the stock 1 piece aluminum units that came stock. They have 2 aluminum fulcrums with a steel bridge for support.
Old May 15, 2010 | 11:58 AM
The Melling replacements are 3 piece units, is that what you mean?
My engine still has the one-piece units in place.
Old May 15, 2010 | 12:05 PM
64Rocket's Avatar
I think it is a bad lifter. The engine probable has a lot of sludge. Run a quart of ATF fluid in the engine. The tick should go away. If the rocker bridge is broke the engine will have a miss to it. The engine is 43 years old, the lifter is proabale wore out.
Gene
Old May 15, 2010 | 12:16 PM
svnt442's Avatar
Yes. I was talking about the replacement units.
Old May 15, 2010 | 12:24 PM
Do most people replace the 1 piece units with those Melling units, and how much trouble is that?
Old May 15, 2010 | 12:50 PM
svnt442's Avatar
The one piece units are not available any more so the answer is yes. I used them in a rebuild 17 years ago and they function just fine.
http://www.4wd.com/productdetails.as...mpaign=product
This Melling part is the replacement, right?
Old May 15, 2010 | 12:53 PM
Gene
I did that last oil chance - 20/50 replacing a quart with ATF - about 1300 miles so far, no change; I even dumped other "miracle" type stuff (mostly ether, I believe) into the crank case - no change yet.
Old May 15, 2010 | 02:13 PM
SEALED POWER Part # MR1840 are the straps,
SEALED POWER Part # MR1903 are the pedestals.
Old May 15, 2010 | 02:26 PM
66ninetyeightls's Avatar
Land Yacht Captain
Don't 330's have rocker setups like this or is that just the older ones??? At least my brother inlaws did. His was noisey above 2000RPM. We found a few of the rocker bolts loose. Once we tightened them up the noise went away.
Old May 15, 2010 | 02:52 PM
Those must be older - like these replacements:
Old May 15, 2010 | 02:54 PM
svnt442's Avatar
The shaft mount rockers were 64 only.
Old May 15, 2010 | 02:56 PM
Supercars Unlimited shows a couple of solutions - assuming the actual rocker piece is intact:
1:
2:
As well as arms:
Old May 15, 2010 | 03:22 PM
svnt442's Avatar
Wow I didn't know anyone was still making the original style bridges.
Old May 15, 2010 | 10:02 PM
Land Yacht Captain
I just replaced these on my 425. I ended up with a mix of both styles. Gotta say I liked the fit & finish of the new 3 piece units MUCH better.
Babafats
Feb 1, 2014 08:10 PM
rcdynamic88
Nov 9, 2013 10:34 PM
CutlassLegend
Sep 21, 2011 02:56 PM
young olds
Apr 25, 2010 04:15 PM
jimmison2009
Jul 13, 2009 09:01 PM
