rocker adjustments
Old Mar 7, 2015 | 07:24 PM
billmerbach's Avatar
major noob
Question rocker adjustments
I'm sure this has been covered but I can't find detailed instructions to adjust stock rockers the book I have says tighten to 25ft pounds and be done with them is this the case
Old Mar 7, 2015 | 07:31 PM
tru-blue 442's Avatar
Old School Olds
Yes. No adjustment on stock rockers.
Old Mar 7, 2015 | 07:34 PM
major noob
Any particular order I got this annoying knocking band I'm trying to eliminate it or the are I need to look for
TripDeuces's Avatar
Yes, you're just setting the rocker bridge down on the head. Just remember to do each bridge equally or as close to equal as possible. Unless you do each one on the base circle you could crack a bridge
Old Mar 7, 2015 | 07:37 PM
83hurstguy's Avatar
Provided you have stock rockers, unmilled heads, stock valve height, unmilled block, and stock length pushrods, yes, this is the proper procedure. Small deviations won't make much of a difference, but they can add up. I don't have any other info available to me for a while to remember how sensitive they are, or how much lifter preload you need to obtain.
major noob
So just take my trusty torque wrench and set it to 25 ft lbs and tighten? Ok I will do this until now I have just tightened them till I can't tighten them anymore with a ratchet lol
Old Mar 7, 2015 | 07:43 PM
cjsdad's Avatar
True! The factory valve train is not adjustable on the Oldsmobile engine. The hydraulic lifters do have a small amount of flexibility to compensate for the minor differences in valve stem length/installed height. But that is about it. Adjustable rockers are available through the aftermarket.
Old Mar 7, 2015 | 07:49 PM
Octania's Avatar
Seems like that would vary, depending on
your ratchet
how much Wheaties you had for breakfast
your arm's calibration
the lube appied to the bolts...
etc.
A torque wrench on oiled fasteners is the CSM proper method.
cjsdad's Avatar
The rocker bridges should be tightened equally with both bolts at the same time. Or they can be broken as TD mentions. I'm pretty sure that is what happened to mine.
Old Mar 7, 2015 | 07:52 PM
major noob
Well my neighbor calls me he bolt breaker cause no matter what I'm tightening I bust a bolt and I haven't busted these yet lol
Old Mar 8, 2015 | 06:59 AM
Need more detail on this part. Can you better explain?
Old Mar 8, 2015 | 07:02 AM
major noob
Any order to tighten the rocker arms to 25 ft pounds.....I'm thinking its this that is causing my knocking/ticking noise its on the passenger side
Old Mar 8, 2015 | 07:18 AM
Macadoo's Avatar
Bill, did you have any head work done? The machine shop I went to installed new exhaust valves on every cylinder. Those valve stems ended up being shorter than the stock intakes so I wasn't getting enough preload. And the cam I put in has a smaller base circle, further exacerbating the problem. I had a lot of ticking.
Any more details you can give us? Can you measure your preload? I used a very straight piece of hard wood across the valve cover surface, placed my caliper on that (mine has the pin that slides out when I open it), tightened the bolt until zero lash (slight resistance on the pushrod), and took a measurement. Then I torqued the bolts to 25 ft lbs and took another measurement, then subtracted. You should have between .030 and .060" preload. Some of mine had as little as .015.
It's really not difficult. If you are torquing them to 25 and still getting ticking, something is amiss.
Old Mar 8, 2015 | 07:26 AM
major noob
Not that I know of but it apparently has an rv cam idk the specs maybe its the lobiness of the can I'm hearing?
Old Mar 8, 2015 | 07:51 AM
Bring each cylinder to TDC on its compression stroke, with the lifters on the base circle, and tighten both rocker screws there.
It's also a good place to double-check your lifter preload - As I said here, just the other day:
"[You can get a rough sense of your valve adjustment by] using the known thread pitch of the rocker pedestal screws (18 per inch or 0.556" per turn) to indirectly measure lifter preload. Considering the 1.6:1 rocker arm ratio, every ⅓ of a turn of the rocker screw will correspond to 0.029" of movement at the pushrod, and since the desired lifter preload is usually given as 0.030-0.060" (I've never seen any one "definitive" number), that means that:
If you place a cylinder at TDC compression and you loosen the rocker screws, then tighten until the pushrod is just making contact with the rocker, then tighten another half a turn or so until the screw bottoms, that valve is adjusted correctly.
If it takes over ¾ of a turn before it bottoms, your preload is a bit deep, indicating a need for a shorter pushrod (or, if you're not going to overstress the engine, shimming the rocker pedestal).
If it takes less than ⅓ of a turn, it's a bit shallow, and you need a longer pushrod (milling the rocker pedestals is possible, but doesn't make much sense unless you've got a milling machine)."
Also, if you're already loosening the rocker screws, you might as well remove the rocker bridges and pedestals and have a close look to see whether the undersides of the bridges, where they bear on the rockers, are worn.
Old Mar 8, 2015 | 08:03 AM
Macadoo's Avatar
Oh sure Eric, you couldn't remember this process when I needed it
Old Mar 8, 2015 | 09:07 AM
Can you narrow it down to the ones that tick or do they all?
Old Mar 8, 2015 | 09:31 AM
Yeah, sorry. I just happened to have a few minutes at the right time to run through the numbers again.
I believe that in your case, though, you have different rocker attaching screws, with a different pitch, because of the different rocker arrangement, so the numbers would be slightly different.
Besides, in your case, you needed to change your pushrod length, which is a whole different ballgame.
Old Mar 8, 2015 | 09:45 AM
Macadoo's Avatar
Yeah, that was back when I was still messing with the stock rockers. I was just giving you a jab
Macadoo's Avatar
X2 Bill. We need more info.
Old Mar 8, 2015 | 10:03 AM
major noob
Its passenger side I believe I got it I do have a loose rocker even after tightening to spec but I tightened head bolts as well and the tick is barely noticeable so I'm making a step in the right direction
Old Mar 8, 2015 | 04:18 PM
major noob
Well the pinging has been solved its the headers.....I used a piece of steel as a stethoscope and the metallic ping is the combustion I guess because the headers are old and rusty they don't insulate sound as well as they used too....would I be correct in my thinking
Old Mar 8, 2015 | 04:34 PM
Headers add a very unique sound to the exhaust. Make sure your gaskets are not leaking and periodically tighten the mounting bolts and collector flanges.
Old Mar 8, 2015 | 04:39 PM
major noob
Well this is at the engine valve covers are silent no noise in there.....headers are tight as ever when I hold a steel rod to each header tube I hear the noise its metallic and ticking just like I'm hearing when I stand over the engine
Old Mar 8, 2015 | 05:04 PM
major noob
Now that I think about it I'm using manifold gaskets instead of header gaskets
Old Mar 8, 2015 | 06:31 PM
major noob
All along it was gaskets.....don't kill me but I poured oil I had from my oil change today over the #1cylinder flange and I saw in the corner a bubble...now I know where there is one leak there will be more so that is the issue
Old Mar 8, 2015 | 06:52 PM
There ya go. Minor exhaust manifold leaks can often sound like ticking.
An easy fix, and you don't have to worry about it for now.
Old Mar 8, 2015 | 06:56 PM
major noob
I'm glad I found it I got work tomorrow and I'll be making money this week so I'll take it to an exhaust shop since I also need to have pipes ran
golds56
Dec 13, 2011 05:53 PM
1973olds98
Nov 24, 2010 02:19 AM
Ausraven
Nov 2, 2010 08:57 PM
nelsontj
Mar 4, 2009 03:33 PM
aristellier
Oct 4, 2006 04:50 AM
