Remanuafactured 1705(76-79) Qaudrajet
Old November 25th, 2021 | 01:14 PM
Charlie D's Avatar
307 & Joe have been helping me with my Studebaker/Olds 307 project. I am going to go with a Quadrajet after the modification in '76 and before the CCC models. I searched eBay for used ones as well as Rock Auto for new ones. The one that keeps standing out to me is the United Manufacturing 11-1230 which appears to have the correct linkage. I am a little confused however with the manual vs. automatic Quadrajets. An article I found gave the interpretation for the ID number. It says that if the last letter is even it is for an automatic and odd = manual. I am guessing it might have something to do with the linkage. My 17084258 CCC carb has the linkage for the cable coming from the automatic tranny. If the carburetor I end up with does not have the correct linkage I am hoping my linkage can be removed from the shaft and placed on the new carburetor. If things go right I plan to attach a couple of pictures of my linkage.
Charlie D.
Old November 25th, 2021 | 01:37 PM
olds 307 and 403's Avatar
Out of Line, Everytime😉
I had a 76 350 carb without the kickdown stud, on the gas pedal but the linkage had the spot and the correct shaped linkage. The studs are available aftermarket. It should have the right linkage, it just may need drilled for thr stud.
Old November 25th, 2021 | 04:49 PM
It’s been discussed several times that the even / odd application info out there is incorrect.
1965cutlassragtop
March 18th, 2017 06:59 AM
lemoldsnut
September 24th, 2014 03:30 AM
4424me
May 13th, 2012 06:02 PM
mauls
September 10th, 2011 07:55 AM
66ninetyeightls
May 18th, 2010 02:59 PM
Quick Reply: Remanuafactured 1705(76-79) Qaudrajet
