carb throttle linkage
Old Sep 14, 2010 | 01:41 PM
mauls's Avatar
Green Horn
Where can i find a throttle linkage like this? The previous owner had a cable with two screws rigged up, it has a lot of slack and I don't trust it.
I'm running a Holley carb if that matters?
Old Sep 14, 2010 | 01:48 PM
66ninetyeightls's Avatar
Land Yacht Captain
Hey thats my picture!! LOL
I made that linkage myself. I got the steel Rod from the local hardware store and purchased the ball joints from a local store that sold hydraulic components.
Measured/cut and threaded both ends. Easy Peasy
Old Sep 14, 2010 | 01:49 PM
mauls's Avatar
Green Horn
Ahh thanks! Yes I dug that picture up from one of my old threads.
I'll try my handy man skills out and try to make one
Old Sep 14, 2010 | 01:51 PM
Well, there's your problem right there...
Seriously, I went through this when I put the E-brock on my 62. You can get end fittings and threaded connector rods from McMaster Carr (www.mcmaster.com). Here's more info from my previous thread:
https://classicoldsmobile.com/forums...dark-side.html
Scroll down to post #19 for pictures of my setup.
Old Sep 14, 2010 | 02:00 PM
mauls's Avatar
Green Horn
both of those setups look great!
Kind of confused on how to measure though. I guess you can't get an exact measurement until you hook each end to the lever, and the carb, then tighten them down on the threads until it is where it needs to be.
Old Sep 14, 2010 | 02:03 PM
Land Yacht Captain
I threaded the firewall side. Then laid the entire rod across to the carb. Marked where the ball joint was on the rod and made sure I had enough thread to do whatever adjustment I needed.
Old Sep 15, 2010 | 05:48 AM
For a time I also used a similar setup on my 64 98 with an Edelbrock carburetor. It seemed to work ok.
Old Sep 9, 2011 | 07:56 PM
ddx77's Avatar
Throttle Linkage
Thanks again Joe...
From mcmaster-
6058K25Ball Joint Linkage Shielded, Steel, 1/4"-28 Right-Hand Thread Size (Same as 6058K22) $2.54
6058K32Ball Joint Linkage Quick-Disconnect, STL, 1/4"-28 Right-Hand Thrd Size
$4.01
93250A060Type 316 Stainless Steel Threaded Rod 1/4"-28 Thread, 1' Length
$2.43
Old Sep 9, 2011 | 08:10 PM
Drew, I see you use Nylock jam nuts.
Do you wear a belt and suspenders, too?
Old Sep 10, 2011 | 07:55 AM
ddx77's Avatar
Well now that you mention it Eric, they were running a special, "get a belt and matching suspenders" with every Nylock jam nut you buy". I only wear them when I am working on the cutlass. The old lady that lives next door to me loves it!
1965cutlassragtop
Mar 18, 2017 06:59 AM
jimmies442
Dec 28, 2013 12:52 PM
CutlassLegend
Sep 14, 2011 11:34 AM
66starfire
Dec 21, 2006 01:57 PM
1964 oldsmobile 442
Sep 5, 2006 11:19 PM
