Rear main seal
Old Sep 19, 2015 | 10:34 AM
transman74's Avatar
Rear main seal
The rear main seal on my 1988 307 is leaking. I've heard that the two piece rope seal can be replaced with a two piece rubber seal. Anyone heard of or done this? If you have, I'd sure like to know what seal you used.
Thanks all
Old Sep 19, 2015 | 03:07 PM
Thanks all
SEARCH is still your friend. The 307 and 350 rear main seals are the same.
https://classicoldsmobile.com/forums...-question.html
https://classicoldsmobile.com/forums...pe-rubber.html
https://classicoldsmobile.com/forums...main-seal.html
https://classicoldsmobile.com/forums...questions.html
Old Sep 19, 2015 | 08:37 PM
olds 307 and 403's Avatar
Out of Line, Everytime😉
Yes AMC 258 straight 6 with the tabs cut off or a Ford 292 seal. There is now an actual Olds part number for the neoprene seal.
Old Sep 20, 2015 | 10:48 AM
transman74's Avatar
Rear main seal.
Thanks to both of you for the information. Would you have the olds part number available for the neoprene seal?
toneypenna
Oct 7, 2010 05:19 PM
Robert Kiedrowski
Oct 19, 2009 07:07 AM
Gbobby
Mar 15, 2009 02:55 PM
65cutty
Sep 23, 2008 10:07 AM
gearheads78
Apr 17, 2008 05:03 PM
