Quadrajet or Summit carb?
hey all. Question here. I have a 77 Cutlass. Did the headers and exhaust. Going to be putting on my new cam and rpm intake. Also will be doing rear gear 3.73. Currently on the almost stock engine the PO installing a refurbished quadrajet. Seems to run pretty good. I have a new Summit racing 600 cfm carb. I have already jetted it and I know these carbs well unlike the quadrajet. I am leaning towards using the Summit carb untill the spring when I'll be able to do the holly sniper efi. I wanted to ask your thoughts. Thanks you
The qjet can be a fantastic carb, with the right knowledge and investment (time and/or money).
But if you're in a pinch and the qjet isn't working well, then the summit carb is probably a fine short term band aid.
FWIW, dollar for dollar, I'd rather invest in a good qjet setup (rebuild by a good company, time spent learning how to tune it, investment in parts) than a TBI. A perfectly running TBI will run marginally better than a carb (other than cold start. Yippee.), while an average TBI is far worse than a good carb.
If the car is running with the Qjet then just keep driving it. If you want to put EFI on it later then do your research and make sure you get the right one. No need to swap to the Summit carb you have unless the Qjet is giving you trouble.
Dead Reckon
Non-Olds Engines
March 15th, 2015 08:10 PM
Creativeindy
September 10th, 2012 01:21 PM
Oldsguy
February 26th, 2010 06:55 PM
