Qjet Throttle Return Spring
What throttle return springs are you guys using for your 4BBL Quadrajets?
I have read where you don't want to heavy of a spring. Some use one spring, some double up. Some springs are color coded. Any advice?
d1
d1
I think the repro parts places sell you the same spring that's used to hold on the OAI plastic flapper top.....it's typically painted white. It seems to have the right tension/thickness/etc when compared to old original QJet throttle return springs I have found.
I didn't realize I had the wrong spring connected to my quadrajet until an Olds mechanic noticed. It was installed by the prior owner.
So, I found a correct spring at The Parts Place for under $10. They shipped it immediately. Wish I had a picture to share but I'm away right now.
Some use heavier springs for a feeling of safety (to avoid any toyota-type "sticking" issues)...
However, that can increase wear on the carb bushings and linkages.
Doubling up lighter weight springs is not a bad idea, so that the combined pull is about equal to the stock single spring.
I can't tell from the picture. What kind of bracket is that? I am assuming you are having the spring pull the throttle linkage back from the front of the carb vs. the rear of the carb (if that makes any sense). From what I have read pulling from the front (better geometry) puts less wear on the shaft.
Oh, I just picked up a "GM" spring from NAPA. It seems to do the trick. Not to heavy where it wants to slam shut and not too light either.
d1
I think I was driving my 72 CS around for a year with the spring off completely , was wondering why the gas pedal was so easy.lol...the bracket it normally hooked to broke , so i had to attach one end of the spring to a clip on the alternator bracket
defiant1
February 16th, 2014 06:00 PM
