Qjet Throttle Return Spring
Old May 9, 2011 | 07:18 PM
defiant1's Avatar
Question Qjet Throttle Return Spring
What throttle return springs are you guys using for your 4BBL Quadrajets?
I have read where you don't want to heavy of a spring. Some use one spring, some double up. Some springs are color coded. Any advice?
d1
Old May 9, 2011 | 07:50 PM
70Post's Avatar
I think the repro parts places sell you the same spring that's used to hold on the OAI plastic flapper top.....it's typically painted white. It seems to have the right tension/thickness/etc when compared to old original QJet throttle return springs I have found.
Old May 11, 2011 | 09:04 PM
olds 307 and 403's Avatar
Out of Line, Everytime😉
This one.
Old May 11, 2011 | 10:48 PM
stlbluesbrother's Avatar
I didn't realize I had the wrong spring connected to my quadrajet until an Olds mechanic noticed. It was installed by the prior owner.
So, I found a correct spring at The Parts Place for under $10. They shipped it immediately. Wish I had a picture to share but I'm away right now.
Old May 12, 2011 | 02:31 AM
Yellowstatue's Avatar
It also depends on how large your foot is and how many hours do you intend to drive in one day...
Old May 12, 2011 | 05:42 AM
Lady72nRob71's Avatar
Some use heavier springs for a feeling of safety (to avoid any toyota-type "sticking" issues)...
However, that can increase wear on the carb bushings and linkages.
Doubling up lighter weight springs is not a bad idea, so that the combined pull is about equal to the stock single spring.
Old May 12, 2011 | 07:26 AM
defiant1's Avatar
This one.
I can't tell from the picture. What kind of bracket is that? I am assuming you are having the spring pull the throttle linkage back from the front of the carb vs. the rear of the carb (if that makes any sense). From what I have read pulling from the front (better geometry) puts less wear on the shaft.
Oh, I just picked up a "GM" spring from NAPA. It seems to do the trick. Not to heavy where it wants to slam shut and not too light either.
d1
Old May 12, 2011 | 10:04 AM
Shizzy's Avatar
I'm running the parts store universal bracket and springs on mine. Its a 73 Quadrajet with a mid 80's Quadrajet throttle arm welded on. works great.
Old May 12, 2011 | 10:32 AM
oldsguybry's Avatar
NOVICE car nut
I think I was driving my 72 CS around for a year with the spring off completely , was wondering why the gas pedal was so easy.lol...the bracket it normally hooked to broke , so i had to attach one end of the spring to a clip on the alternator bracket
defiant1
Feb 16, 2014 06:00 PM
mv64cutlass
Jul 20, 2011 06:05 AM
4-Speed
Apr 2, 2010 02:27 PM
Flye
Aug 30, 2009 05:18 AM
68conv455
May 20, 2008 02:03 PM
