Pushrod selection
Pushrod selection
Hi all,
I'm at the point in my engine rebuild where I need to select pushrods and possibly new rockers. I had the heads done at a local shop and one valve looks like it sticks out .020-.030 farther than the rest. Pictured below. What would be the best and cheapest way to account for this? Could I shim the rocker stud to fix the geometry or am I going to have to switch to an adjustable set up?
Thanks,
-Mike
Thanks,
-Mike
Here is a picture of the lifters. I'm not sure how to adjust them. Most of the parts came in a kit with my camera, a Complete Cams 42-221-4 kit. Side question, do I take the clips out of the top of the lifters?
Do not take the retainer clips out of the lifters. I see pushrod guide plates installed, which is not a stock set up, what type of rocker arms do you currently have? Stock rocker arms do not need the guide plates.
Mike, your rocker arm kit will probably account for the that stem being a little tall. The weak link is the poly lock nuts. Some people like to replace those, sooner or later you might need too.
Do not take your lifters apart.
Ideally you want those valve heights consistant, for now I'll think you'll be fine.
Its not necessary to soak your lifters. It might cause a false reading leading when setting them .
You really need to measure for proper push rod length, using a checking push rod. The ones supplied in the kit might be ok, or they might a little long.
Can you put a straight edge across the top of all the valves and actually see how far off, if any, it is?
My other thought is since you are using an adjustable set up there probably won't be any problem.
It seems like the third from the front on the driver side is the only one that is off. It is taller than the rest so it's tougher to measure than a short one.
Not at all or your valves will be stuck open.
As the valve seats are ground, the valve sits higher in the head, more protruding stem. Thus you need more pushrod protruding as well. You're not that far off, just losing a little bit of cam lift which may already be more than the head can utilize anyway, unless the head is ported and flowbench tested to determine which cam you should use.
You have an adjustable pushrod, so why don't you use it and figure all this out???
You can see if your lifter compressed or not by watching the plunger. New lifters don't want to compress easily. The last set I installed needed the engine to fire up before they would compress. I'm not sure what they were filled with but it was significantly stiffer than oil (Comp).
You're fine. Typically you want to check pushrod length at zero clearance, skip the 1/2 turn extra. You're still approximately in the middle of the valve tip. Getting that geometry corrected may be worth 10hp, but you're splitting hairs if the rest of the build isn't done to that same meticulous level.
Nice, thanks! I will still check the other head and the one valve that is sitting proud to make sure everything is good. I'm not trying to build a race engine or anything, just want a little more hp than stock since i have it open anyway.
RAMBOW
Brakes/Hydraulic Systems
February 2nd, 2015 06:07 PM
