Pulling the motor
Old Oct 22, 2013 | 05:15 PM
  #201
Valves are hardened, it takes a lot of effort to take off metal.
I know... but... It just feels wrong.
Old Oct 22, 2013 | 05:37 PM
  #202
Macadoo's Avatar
Originally Posted by coppercutlass
I have a complete top end I'm selling but you will need better pistons. #8 heads, with 20k miles on em clean , edelbrock intake, rollertip rockers
Thanks Copper but I'm not ready to get into the short block.
The compression test was okay but a little inconsistent. 160 high to 120 low. No appreciable change after adding oil. Hence I'm thinking valves. I'm still not convinced it's only 52k miles after seeing inside the exhaust ports but I'm certainly no expert.
I have a C-type spring compressor...if I can find it. I haven't done this in years. I like plan A 1/2. Disassemble the heads, clean the valves (I have a drill press and a couple of bench grinders with wire wheels), lap the valves, take in heads to have them cleaned and tested (If I frock it up, I'll pay the higher labor charge, it's only fair). Reassemble myself.
Like I said, I'm no expert but the exhaust ports seem pretty grimy. Can the machine shop also check the guides? That's something I would like to know and don't trust myself to check.
Old Oct 22, 2013 | 05:38 PM
  #203
coppercutlass's Avatar
Chevy budget Olds powered
No biggie just thought id let ya know in case all the maw's kick in .
Old Oct 22, 2013 | 05:40 PM
  #204
Macadoo's Avatar
If the valves are lapped instead of resurfaced it is critical that they are kept in order and put back in the same port they were in originally. The advantage to lapping a valve is that it will let you see if the valve and seat are making good contact i.e., the width of the contact area on both the seat and the valve and where the contact is made in case it is too close to the edge of the valve face (the valve is usually worn too far if this is the case).
Ask the machine shop if they would check the head for straightness and do a vacuum test on the valves after they are lapped. This is quick, inexpensive and lets you know if they are sealing properly. They put a rubber disc over the chamber area with the valves in and closed, apply vacuum and see if it holds.
Did you do a compression test before pulling it apart?
Compliments on getting the exhaust manifold bolts out without breaking them!!!
Thanks Sugar Bear. I hope the other side comes off as easy. And yeah, egg cartons standing by for the head parts.
Old Oct 22, 2013 | 05:50 PM
  #205
Then I would go with plan B, just take them the heads and the springs. They will look like new when you get them back.
Old Oct 22, 2013 | 07:26 PM
  #206
Sugar Bear's Avatar
The machine shop can check the guides with the springs removed but need the springs installed to do the vacuum test. They can measure the guide wear but would likely just move the valve slightly off the seat moving/rocking the valve stem back and forth in the guide and be able to get a good idea of the guide condition. Remember that excessive movement in a guide can also be due to a worn valve stem.
If any guides are replaced, the valves and seats with new guides should be refaced not just lapped. If you do need a lot of guide work you may consider having a complete valve job done at the machine shop.
Old Oct 23, 2013 | 03:42 PM
  #207
Macadoo's Avatar
Just out of curiosity, should there be any movement of the valve stem in the guide? What I mean is; if I pull the springs, slide the valve about half way down and can feel even the tiniest lateral movement, does that mean i need new guides?
Old Oct 23, 2013 | 09:29 PM
  #208
Sugar Bear's Avatar
Yes there should be some movement, but very little. This is where a machinist would know just by looking or measuring how much movement is excessive. You could compare the tightest guide to the most worn one to compare. The exhaust guides will probably be the most worn due to the heat.
How many miles are on the motor, was it clean inside and did it use any oil? If it is not a high miler or an oil burner and did not have sludge, the guides are probably not excessively worn.
Old Oct 24, 2013 | 07:09 AM
  #209
There is a specification for this, which usually involves pulling the valves out a very small amount and measuring their side-to-side deflection with a dial indicator.
I'm not sure what it is for Olds, but probably a few thousandths is reasonable, with 0.008" being too much, and 0.002" being too optimistic.
Old Oct 24, 2013 | 07:02 PM
  #210
Macadoo's Avatar
Good info, thanks guys. It'll be a little while before I get the heads off but I'll let you know.
Old Oct 25, 2013 | 08:48 AM
  #211
Macadoo's Avatar
Worked a 13 hour day yesterday but it bought me the day off. I got the other manifold off this morning without too much trouble. Had to break out the heat for the middle bolt. You're right, the Map/Oxy doesn't get all that hot but it worked.
One of the exhaust ports and accompanying valve stems looks wet when all the others look dry. Maybe a bad stem seal?
I've also been working on the broken manifold to exhaust pipe bolts but they're being a little more stubborn. I've got some time before the manifolds go back on though. I'll keep spraying them over the next couple of weeks.
Old Oct 25, 2013 | 08:58 AM
  #212
Those manifold-pipe bolts will need heat and lots if it.
That's likely all that will work.
Keep pouring the heat into the tabs with that torch, like for 5-10 minutes per bolt, until they're a dull red, and they'll turn out.
Afterward, chase the threads.
Old Oct 25, 2013 | 09:59 AM
  #213
oldstata's Avatar
Justin
Yes I would of worked on it while bolted to the head on the engine stand so you could heat it up and not have it flop much but a good vise would help too
Old Oct 25, 2013 | 10:49 AM
  #214
Macadoo's Avatar
Thanks for the advice fellas. I have a heavy duty vice, flopping isn't the problem. I'm not up for a battle today so I'm moving on to things more fun....removing the oil pan and front cover. I'll keep spraying the bolts but I may use them as an excuse. "Honey, those bolts just won't budge. I may have to go with those shorty headers after all."
Old Oct 25, 2013 | 01:49 PM
  #215
Macadoo's Avatar
Smile, you're on missing-teeth camera!
[IMG][/IMG]
Do these engines bend valves when the chain jumps? I don't have the front cover off yet so I don't know for sure that it jumped. The chain seems loose but not floppy. Good thing I have a new timing set in my cabinet.
And that orange stuff looks very much like the silicone that was behind the water pump. Is that likely? There was "clean" antifreeze in the little pockets of the block, just inside and under the oil pan mating surface. I thought maybe that happened when I turned the motor upside-down on the stand. The oil was a little dirty but not foamy at all.
And uhh.....how do I clean this out?
Old Oct 25, 2013 | 03:52 PM
  #216
You can separate the pickup tube from the oil pump and back wash it. To aide in cleaning it out I use a dental pic or some stiff wire.
Old Oct 25, 2013 | 04:00 PM
  #217
Macadoo's Avatar
Should I remove the pump before pulling the tube? I wouldn't want to drop anything into the motor.
  #218
Professur's Avatar
Looks like bacon
Old Oct 25, 2013 | 04:28 PM
  #219
M-14's Avatar
I wonder if you could put the exhaust manifolds in a grill for awhile & then try to loosen up those studs.
Old Oct 25, 2013 | 04:30 PM
  #220
Macadoo's Avatar
mmmm....bacon.
Old Oct 25, 2013 | 04:31 PM
  #221
Macadoo's Avatar
Maybe a grill with a leaf blower. I've melted aluminum that way but it took a lot of charcoal.
Old Oct 25, 2013 | 07:18 PM
  #222
67 Cutlass Freak's Avatar
Nice job
I just found this thread and I have to commend you for your efforts. That does look like silicone in your oil pick up, but it didn't come from the water pump. Someone along the way got carried away with it's use. Maybe oil pan, intake, or timing cover? When you pull your valves, look very carefully at the seat area. Does it look straight or concave? Sometimes it helps to hold two valves together from opposite directions. Can you see light between the seat area on the valves? If so, you should plan on doing a valve job. I recently picked up a valve grinding machine and two nice seat grinders. I live just over the boarder into Wisconsin so you would have a pretty good drive to get them to me. I would charge $100 to do your valve job plus any parts. I can replace guides, but not seats. I would still recommend having them hot tanked, checked for cracks, and resurfaced. My machinist charged me $120 for the last set I brought him, disassembled. If you decide to take them to a local machine shop, make sure they have a valve stem height gauge for Oldsmobile's. If they don't know what your talking about, get the hell out of there. It is crucial to get the height correct, unless your going to upgrade to an adjustable valve train. Just so you know, I believe your engine came with a rope style rear main oil seal. Those things are a pain in the ***. They do make neoprene replacements, which I would highly recommend. The bad news is, your crankshaft is going to have to come out. You need to be extremely careful when removing the pistons not to damage the crank from the rod bolts. You really should use a ridge reamer on the cylinder bores. If you like doing your own engine building, invest in some good measuring tools and check everything very thoroughly. You should blue print your engine while you have it apart. I could give you a spec sheet if you need one. You should also learn as much as you can about what makes the Olds motor different from all others, and why certain things need to be done differently to make them live. Go to You Tube, and look for a series of engine building videos from Bill Travato-
You may also want to pick up a copy of his book. Sorry for the novel, I thought some of this information might be helpful to you. Once again my hat's off to you for diving in on this thing especially without air tools. Finally I want to give you an idea of what it could cost you to do a full high performance build. Look here-
https://classicoldsmobile.com/forums...ort-block.html
Old Oct 26, 2013 | 06:33 AM
  #223
Macadoo's Avatar
Thanks for the recognition and vote of confidence Freak. I've pretty much decided to take the heads in and have the work done. I appreciate the offer and it's a good price but my truck gets about 12 mpg so it would cost me more to drive up.
I think for now I'll be leaving the short block alone, other than that rear main seal. I'm hoping to not have to remove the crank to pull that rope. I've been doing a lot of reading and it sounds like it can be very easy or very difficult. Luck of the draw I suppose.
I'll also have a better idea of the condition of the rings once I get the heads off and can see how much of a ridge I have in the cylinder. But a wet test didn't change my compression readings so I think they're in pretty good shape. Worst case scenario would be to button her back up and run it and buy a short block to work on in the mean time.
Thanks for the tip on the valve length. That I would not have known.
Old Nov 1, 2013 | 12:37 PM
  #224
Macadoo's Avatar
Huh?
I don't think I get it. The teeth on my cam gear look fine. Or are they supposed to be capped with nylon teeth?
[IMG][/IMG]
If not, then what is all this in my pickup screen?
[IMG][/IMG]
That chain is just a wee bit loose though, yeah?
Old Nov 1, 2013 | 12:46 PM
  #225
That's an original nylon-clad gear, sans nylon cladding.
As you have discovered, the nylon has regrouped in your oil strainer.
That gear is toast, my friend.
Old Nov 1, 2013 | 02:42 PM
  #226
Macadoo's Avatar
Lol, thanks Eric. I think the timing set was the first thing I bought. I had a 90-ish 88 pop a chain and bent a few valves so yeah, wasn't taking any chances.
Old Nov 2, 2013 | 09:21 AM
  #227
Macadoo's Avatar
Hey guys, my inexperience is showing yet again. I bought an Edelbrock timing set, True Rolling Timing Chain set #7813, and the sprockets are bigger than the stock sprockets. Both the cam and crank are bigger so I should assume the geometry will be correct, right? Also, It's a thicker set than stock, a double roller (?). Will that cause any issues with the fuel pump eccentric and the oil slinger? I'll get pic here in a sec...
Old Nov 2, 2013 | 09:30 AM
  #228
Macadoo's Avatar
Also, any tips on removing the crank gear? The harmonic balancer puller set I rented came with a three arm puller. Can I use that?
The old sprocket is the dirty one, to point out the obvious. Now that I'm looking at the photo, the center area of the new sprocket looks to be the same thickness as the old one. I'll measure....
The new cam sprocket looks to be about 1/16 inch thicker.
[IMG][/IMG]
Old Nov 2, 2013 | 10:21 AM
  #229
M-14's Avatar
It's thicker because it's a double roller chain. That's normal.
You can use a 3 jaw puller, just make you don't ruin the crank threads with the forcing screw.
Old Nov 2, 2013 | 11:05 AM
  #230
Macadoo's Avatar
Thanks M-14, unfortunately the puller isn't long enough. I'll hold off until I have the right tool.
Old Nov 2, 2013 | 11:57 AM
  #231
805Cutlass's Avatar
great thread guys. Im planning on pulling out my sb next week, this will be my first time doing this so im trying to prepare myself for it. since im only taking out the engine have any of you used those engine lift plates to pull it out..you kno the ones that bolt on the intake manifold?
Old Nov 2, 2013 | 01:00 PM
  #232
Macadoo try two pry bars and wiggling it out so to speak that's usually what I do. Or I have also used a slide hammer with a axle removal adapter for fwd cars ., all it took was a few very light and I mean light taps with the 10 lb slide hammer and out it came.
Old Nov 2, 2013 | 01:19 PM
  #233
Macadoo's Avatar
Hey Copper, yeah I saw a youtube vid of a fella doing just that. Seemed to come off pretty easy. I hadn't thought about the pry bars though. Both at the same time or one side, then the other?
805 Cutlass, as a newb myself I'd be glad to answer any questions. But first off I can tell you this; once my motor was hanging a few feet ABOVE my engine bay, I was very glad I opted for the sling and not the intake plate.
Old Nov 2, 2013 | 01:23 PM
  #234
Macadoo's Avatar
Making some progress finally. I'll admit, after seeing 71supreme's thread about excess carbon in the lifter valley I was a little worried.
https://classicoldsmobile.com/forums...-build-up.html
But it turns out mine is nice and clean.
[IMG][/IMG]
Making some headway. I asked around and got some good leads on machine shops for the head work but I probably won't get those off this weekend. Hopefully next.
Old Nov 2, 2013 | 01:29 PM
  #235
I use a plate 90% of the time when pulling engines only or with the trans attached.
Old Nov 2, 2013 | 01:50 PM
  #236
Macadoo's Avatar
Really [other] Eric? I wouldn't have expected that. Good to know.
Old Nov 2, 2013 | 02:19 PM
  #237
Macadoo yes on opposite sides at 3 and 9 if you where to use a clock for placement guiedance.
Old Nov 2, 2013 | 02:43 PM
  #238
It does look very clean in there. Have you decided if your going to send the block out also?
Old Nov 2, 2013 | 07:33 PM
  #239
Macadoo's Avatar
Eric, I have to draw the MAW line somewhere. I think I'll stop with the head work for now. If it comes to it, I can yank it back out and have the block worked on later.
Thanks Copper, I'll give it try.
Old Nov 2, 2013 | 07:42 PM
  #240
oldstata's Avatar
Justin
Great job so far are you doing a cam while it's out and heads off ?
I don't like lifting a motor with the carb mounted. Plate if it has a aluminum intake, just my opinion then again. I just use a chain from the front of one head to the rear of the opus it side
