pulleys not lining up on 350
I am having trouble lining up my pulleys on my Olds 350 in my 72 cutlass convertible. The motor had the alt on the passenger side and I wanted to put my AC back on so I took the pulleys off of my 1970 455 and tried to put them on the 350. Needless to say I have fitment issues.
Am I missing something? I thought the pulleys were universal between olds motors.
The pulleys correspond with the length of the water pump being used. Grooves in the pulley dont matter. Its the shaft length that differes. Generally there are 3 different ones. Short one is approx 5.2", med is 5.6" and long one is 6.0" - measured from timing cover to the fan/pulley mount.
Measure both of yours --- and if they are different, then you have to use the pump that was working with the pulleys for that pump. If this is you problem and you dont want to switch the pump --- then you could always go out and buy a new one like the one on the 455 and put it on the 350. Either way will solve your problem.
Well, I fixed the problem. I did what one of you suggested and used the water pump from my 455 and installed it on my 350 and now all the pullies line up straight and true. Thank you guys. I've now connected my AC again and its blowing cold
T.
