Problem ? ring end gap
Old Dec 7, 2007 | 12:22 PM
The_Jeremiah's Avatar
hey guys, so i have been working on my 69 350 for awhile now, and the bore ended up being only about .015 over instead of .020 over (i have .020 pisons to go in). so we tryed recalibrating the boring bar and boring again, the piston fits in, but its a little loose. the ring end gap for the top ring at about 2 inches from the top of the bore, is .020. is this ok since the piston fits decently, or should i go to .030 pistons and .030 bore ? im planning on drag racing the car every once in awhile. thanks a lot
Old Dec 7, 2007 | 12:53 PM
kevinkpk's Avatar
Been a long time since I've delt with piston engines to that extent. .020" seems kind large to me, If it's too gapped you'll loose compression and use oil, also run the risk of breaking it, I am sure someone with more knowledge can post.
Old Dec 7, 2007 | 02:22 PM
442Harv's Avatar
What brand and type off pistons? KB pistons take more gap than that on the top ring.
Old Dec 7, 2007 | 07:06 PM
88 coupe's Avatar
Junior Member
........ the bore ended up being only about .015 over instead of .020 ........
Take the pistons, along with the block, to a competent machine shop.
They will be able to correctly fit each bore to an individual piston, using a power hone. This will eliminate the "can of worms" you are about to open.
Norm
Old Dec 7, 2007 | 07:23 PM
kevinkpk's Avatar
Norm
The cylynders should be honed even after boring them. Good point
Old Dec 7, 2007 | 08:06 PM
they are federal mogul pistons, and rings. the only number i have been able to find in a book, is the ring end gap cant be any less than .015. and small block chevys are all .010 to .020
wabasto
Dec 23, 2015 01:09 PM
orange442
Jul 9, 2015 04:32 PM
oldspackrat
Aug 10, 2014 10:03 PM
jims2000lt
Oct 10, 2013 07:56 AM
dman0712
Apr 13, 2010 06:38 PM
