Priming the oil pump
Old Nov 19, 2008 | 11:05 PM
Wasted's Avatar
Im getting close to starting my engine for the first time.So I was wondering if theres a certain tool i would need to prime the engine? Do I just turn the oil pump drive shaft??
Old Nov 20, 2008 | 12:59 AM
64Rocket's Avatar
You will need a 5/16 socket 1/4 drive and an extenion and a drill. I use an 1/2 drill and run it backwards. Be sure to have the filter on and to oil hole where the oil sender goes pluged. I use a brass fitting screwed in the sender spot and a small oil gauge on it. I get 50 pounds with the drill running and have someone turn the engine over with the starter. Lube's all the parts.
Gene
Old Nov 20, 2008 | 05:37 AM
captjim's Avatar
Gene
Instead of plugging the oil pressure port, I hook up a gauge, that way you will know if you have sufficient oil pressure. As Gene stated, you want 50 or so on the drill. I usually do this with the valve covers off and I stop when I see oil at all of the rockers. Also, be very careful that the socket does not fall off. I use a deep (longer) socket.
Old Nov 20, 2008 | 10:34 AM
HARDLUCK88's Avatar
ROCKETeer
is it okay to just unplug the distributor and turn it over with the starter to prime the oil pump?
Old Nov 20, 2008 | 10:51 AM
captjim's Avatar
Not in my opinion, especially on a fresh rebuild. It hakes a while even on the drill to get oil everywhere. It is easy, only takes a few minutes, and is better. I prime them initially on the stand so if there is an issue I can address it before I bolt the engine in the car. Then, I hit it again right before start up.
Old Nov 21, 2008 | 02:02 PM
Warhead's Avatar
Before I owned 6 drills that all go in reverse, I would use a 1/2 drive speeder T reduced to the 5/16'ths, that I would hand crank for 10 minutes.
Good workout. It really needs to be done.
Move the oil first, then turn the engine 2-3 rotations. Remember, the cam needs to be broken in at 2000+ rpm's for 15-20 minutes.
Do it correctly.
Jim
Old Nov 21, 2008 | 10:26 PM
HARDLUCK88's Avatar
ROCKETeer
Cool
Do it correctly.
Jim
thankx for the info guys!
Old Nov 22, 2008 | 05:59 PM
Wasted's Avatar
Thanks for all the help. Seems alot easier then I was thinking.
Odmark
Jul 28, 2013 04:31 PM
Olds Scott
Mar 11, 2013 07:30 AM
84oldsDelta88
Mar 21, 2011 06:21 PM
JRios
Sep 29, 2010 08:39 PM
dallasite21
Aug 31, 2010 07:54 AM
