Ported vacuum or not
Old Jul 20, 2010 | 12:43 PM
MJAKS462's Avatar
I posted this in a different thread but now I can not find it.
My trans modulater hard line is plugged into a ported vacuum port
The hei vacuum advance is plugged into a full vacuum port.
car has weak acceleration , but starts and idles great , should I flip flop the lines ?
it is a 650 edlebrock carb.
I know I need a tune up (other than spark plugs)but I want to get it as correct as possible before bringing the car in to a shop.
Joe Pavado , you mentioned in the other thread that the trans mod line should NOT be on a ported vacuum port . Is this correct ?
THANKS IN ADVANCE
Old Jul 20, 2010 | 01:26 PM
A TH 400 needs manifold vacuum.
Old Jul 20, 2010 | 01:30 PM
MJAKS462's Avatar
It is a th400 , So I guess I need to hook the trans line to the intake somewhere ?
Old Jul 20, 2010 | 01:32 PM
Yep. Or a manifold vacuum source on your carburetor.
Old Jul 20, 2010 | 01:36 PM
ALL automatic transmissions with a vacuum modulator need full manifold vacuum to the modulator, not ported vacuum.
Old Jul 20, 2010 | 01:41 PM
MJAKS462's Avatar
So if I use the full vacuum port on the carb for the trans line , will it be ok if the hei vacuum advance is plugged into the ported spot on the carb ?
Old Jul 20, 2010 | 01:44 PM
You need to experiment to see if the car runs better with ported or full manifold vacuum to the distributor. It's perfectly acceptable to put a tee in the line and connect both to manifold vacuum if the car runs better that way.
Old Jul 20, 2010 | 01:47 PM
MJAKS462's Avatar
Sorry I dont know much about vacuum , but is the full vacuum port on the carb the same as full manifold vacuum?
I am loooking at my owners manual for the carb and it states that one port is ported and one is full vacuum on the front of the carb.
This is great when we can actually chat instead of waiting hours for help , I sure appriciate it .
Old Jul 20, 2010 | 03:08 PM
Yes, it's just an additional port provided as a convenience. It is exactly the same as a tee screwed directly into a manifold runner. Ported vacuum, on the other hand, is specific to the carb and is connected to a port (get it?) in the venturi that is above the throttle blade at idle but then is uncovered shortly after the throttle is moved off idle. Once the port is uncovered, ported vacuum is virtually the same as manifold vacuum.
Old Jul 20, 2010 | 05:12 PM
Destructor's Avatar
There should also be a manifold vacuum fitting on the manifold in front of the carb, that is where my trans vacuum is tapped into.
Old Jul 20, 2010 | 07:47 PM
MJAKS462's Avatar
GOT it Joe , I will experiment with it. Thanks alot !!
Mongoose
Mar 24, 2014 01:54 PM
88 coupe
Jul 31, 2008 08:54 AM
esisson
Jun 8, 2008 07:59 PM
dan1s
Feb 18, 2008 11:41 AM
ct1979
Dec 22, 2006 10:22 PM
