Ported Vacuum Switch?
Old Dec 22, 2006 | 05:20 PM
ct1979's Avatar
Can anyone tell me how this Ported Vacuum Switch should be connected on my 69 350 cutlass and what it does?
Old Dec 22, 2006 | 10:22 PM
69oldsguy's Avatar
The purpose of the ported vacuum switch is to control the advance at the distributor based on the operating temp of the engine. You should have three ports on the switch. The top port goes to the advance on the distributor. The middle port goes to the ported vacuum port on your carb. The bottom port is connected to manifold vacuum via the port forward and to the left of the carb. If you have an auto trans then there should be a "T" from the manifold vac also feeding the modulator on the trans. Have a good one.
Kevin
Mongoose
Mar 24, 2014 01:54 PM
Olds luvr
Apr 4, 2011 12:30 PM
1973olds98
Oct 28, 2009 07:32 AM
esisson
Jun 8, 2008 07:59 PM
dan1s
Feb 18, 2008 11:41 AM
