Pinging under load
Old Aug 11, 2015 | 09:54 AM
olds 307 and 403's Avatar
Out of Line, Everytime😉
Pinging under load
As of late, with the hot humid weather, I have had pinging, popping out intake and exhaust. I have played around with valve adjustments but thinking it is timing. I plugged the vacuum advance it ran much better. It only pops with the choke on now. The carb is fairly rich at idle and not sure at cruise. The Mallory breakerless has a fairly fast curve, in by 2500, 37 total. My specs are 9.5 to 1, 204/214 cam, custom Qjet with XR5 NGK spark plugs. I have really cold extra set of 5670-8 plugs which are super cold. Would something in a 6 or 7 range be better than my current 5? Would an overly rich mixture cause pinging? I assume this is pinging popping out the intake and exhaust?
Old Aug 11, 2015 | 01:57 PM
pmathews's Avatar
Have you calculated dynamic compression? With that cam and compression, the intake closing event might be too early.
http://www.wallaceracing.com/dynamic-cr.php
Old Aug 11, 2015 | 05:36 PM
Olds442redberet's Avatar
I wonder how it would run with racing fuel in it instead of the junk gas from the local self serve?
Old Aug 11, 2015 | 10:56 PM
Probably better on race gas. I get 8.8 to 1 dynamic and cranking psi should be 180. Plugs look a nice medium brown except 2 and 8 were black.
Old Aug 12, 2015 | 04:47 AM
M-14's Avatar
A rich mixture might be causing incomplete combustion.
I'd work on the carb & make sure the thermac system is working (if you have a stock air cleaner).
Old Aug 12, 2015 | 11:43 AM
No noticeable pinging today and very humid. I have a hood scoop feeding into a 14 X 3.5" tall K&N filter with filter top.
Old Aug 12, 2015 | 10:24 PM
pmathews's Avatar
Assuming the 8.8 to 1 dynamic compression ratio calc is accurate, that is huge. I'm guessing the combination of your cam and compression is way too much, even for 93 octane. The intake valve closing event (ABDC) has the biggest impact on dynamic compression.
My dynamic is 8.5 to 1, and I run 93 octane with Octane Supreme TetraEthyl Lead additive (increases to 94). I also run 34 total mechanical advance, and I limit my vacuum advance to 10 degrees. With a 265 DEH cam, my ABDC is 58 degrees.
What's your intake valve timing on that cam? The closing event (ABDC)?
Old Aug 13, 2015 | 09:56 PM
28 abdc, cam is advanced 2 degrees on my Cloyes set. I should redo the compression test, was 155-170 but ran atf through the motor, might be higher. My 1.72 ratio rockers should also help bleed off a little more pressure.
Old Aug 13, 2015 | 10:03 PM
Only detonated pushing it really hard last night. Filled it with premium before the big price jump.
Old Aug 16, 2015 | 08:07 PM
pmathews's Avatar
28 ABDC seems really low, maybe that's BTDC? My BTDC is 27, my ABDC is 58. Take a look at my camcard...
http://www.compcams.com/Company/CC/c...csid=1179&sb=2
Which brand of cam are you using?
allyolds68
Oct 4, 2014 04:58 AM
56Holiday88
Nov 4, 2011 12:00 PM
defiant1
Aug 8, 2011 03:27 PM
61olds
Jul 12, 2011 01:51 PM
66ninetyeightls
Aug 23, 2010 12:24 AM
