Ping when starting?
Ping when starting?
Not sure how else to describe it, it just sounds like a ping when the engine first catches on start up. Just one and then it runs fine.
For those that haven't read my million page "pulling the motor" thread;
Original 350 with heads refreshed new exhaust valves, a few new intake, seals, etc.), new cam, matching springs, new rockers, double roller timing chain, performer intake, Q-jet, original oil pump with new pickup (40 lbs oil pressure when cruising), HEI "upgrade" etc, etc. Didn't touch the short block.
Running 18* initial, 13* on vac can (hooked to ported, likes it better that way), 48* all in.
Thoughts?
Thoughts?
I try to stick with Marathon. It seems the best around here. The freedom gas (closest to us) gummed up my riding mower so bad I had to clean the carb and unstick the float.
But considering my 8.4:1 CR, I was using the 87 octane. Should I step it up?
You might consider running the midgrade during the really hot summer months and see if that corrects your slight ping on start up. When it's hot, turn the key and start cranking the engine, if the engine spins a bit then push the pedal down a small amount.
I'll give the higher octane a try. And yes, your hot-start procedure seems to work best. Is it partly the higher initial advance?
therobski
October 25th, 2014 12:16 PM
