Overheated! : (
Old May 17th, 2008 | 06:28 PM
UCF72Cutlass's Avatar
Overheated! : (
Was driving on the highway and my car began to overheart. I noticed this and pulled over. I turn the engine off and a bunch of smoke shot out the radiator. Had it to towed to a mechanic. The mechanic shop filled it with some antifreeze and put some new belts on it and its running pretty good. Do you think I need a new radiator and could i have done any damage to the engine?
Old May 17th, 2008 | 07:29 PM
Oldsmaniac's Avatar
It is possible that you were low on coolant and that is what caused the overheating....other things could have caused it also one being a partially clogged radiator. As for damage to the engine...probably none occurred.
Old May 18th, 2008 | 05:40 PM
88 coupe's Avatar
Junior Member
Originally Posted by UCF72Cutlass
The mechanic shop filled it with some antifreeze and put some new belts on it and its running pretty good ........
Sounds like it was repaired. If, since then, you've driven it "on the highway" and it did not "overheat" you can forget it happened.
........ Do you think I need a new radiator ........
If you did, the car would still be "overheating".
........ could i have done any damage to the engine?
Not in the scenario you described.
Norm
TeamXlink
October 20th, 2014 12:21 PM
Double D Farms
July 30th, 2014 07:40 AM
JeremyTA
June 24th, 2011 09:36 PM
