opinions on best SBO heads?
Old May 22, 2007 | 11:39 AM
GoldOlds's Avatar
I've read that the #5 heads are considered best overall SBO heads, but wouldn't #6 or #7 be better because of their larger valves (same 64cc chambers)? Do they all flow the same? I'm still very new to the world of Oldsmobile.
- GoldOlds
Old May 22, 2007 | 07:11 PM
Redog's Avatar
5 or 5a heads from the late 60's early 70's are the best according the Dick Miller.
6 heads are good too, but are rare, they were used in Canadain cars.
The flow between 5, 6 and 7 are close. If there is no little "a" like 5a and 7a, this means they have the hardened valve seats so they can run unleaded gas.
You can also use Big Block heads on the Olds Small block. But opening up the cc cambers too much, will cause a loss in compression, thus a loss in power.
The trick is, take a set of BBO heads, have them milled to .010, and you have flow of BBO heads with a SBO combusion chamber
Old May 22, 2007 | 07:23 PM
skinny's Avatar
So a stranight #7 head (not 7a) will run todays fuels just fine? I was told I would have to get the heads rebuilt to run unleaded, guess my info was wrong.
Old May 23, 2007 | 03:22 PM
Redog's Avatar
A 7 head will run today's fuel fine, but it will cause problems in the future.
Go to your local auto parts store and buy a bottle of lead. About 3 or 4 bucks a bottle, but you gotta run it iat every fill up
Old May 26, 2007 | 10:26 AM
GoldOlds's Avatar
Can that be done? I thought all Olds motors had "non-adjustable valvetrains," meaning that if you mill a set of heads, you have to shorten the pushrods to keep everything working properly... or something like that.
- GoldOlds
Old May 26, 2007 | 12:45 PM
Redog's Avatar
- GoldOlds
There are Olds heads that are non adjustable, but I'm pretty sure they were pre 1968. '68 and up, are different
Old May 27, 2007 | 12:15 PM
GoldOlds's Avatar
By "different" do you mean "adjustable?" That probably sounds like a stupid question, but I want to make sure I don't misinterpret what you're saying. Thanks!
- GoldOlds
Old May 27, 2007 | 05:49 PM
Redog's Avatar
- GoldOlds
Yes, but maybe somebody else can confirm this before you buy
Old May 31, 2007 | 12:46 PM
marcar1993's Avatar
In the Performance section of this web site, there was an article (Valvetrain Geometry) about using shims to adjust the height of the rockers if you milled the heads or went with longer rods. So it can be done.
Old May 31, 2007 | 01:55 PM
Pinner's Avatar
The heads on the olds motors have non-adjustable rocker arms. You could shim under the rocker hold down stems if needed. However, the thickness of shim added would be less than the amount of material that was removed from the head. I'm not sure what that ratio would be.
QS442
Aug 12, 2014 05:56 PM
Oldskool84
Feb 28, 2014 04:14 AM
lilgiff
Oct 20, 2012 10:15 PM
f-85
Aug 15, 2010 11:15 AM
shaks 442 clone
Oct 18, 2008 09:41 AM
