opinions on best cam to wake up #8 head 350???
Old Apr 24, 2015 | 06:34 PM
marklt's Avatar
Hey All....opinion time. What's your pick of best cam (factory or aftermarket) for a 350 olds low comp (#8) head motor, auto to wake it up (and no change to stall converter).
Old Apr 24, 2015 | 08:38 PM
76olds's Avatar
Hookers under Hood
I could be wrong but others will chime in and correct me, I have heard that a comp cams Towing cam would give much more torque. Have a look on the Summit website they list one.
Hope this helps
Eric
Old Apr 25, 2015 | 02:55 AM
DoubleV's Avatar
The smallest cam in the Voodoo cam lineup. That should be a 207/213 duration cam. Had that in my 8:1 Olds 350 with 7 heads. Ran best 13.83 in my 442.
Old Apr 25, 2015 | 08:32 AM
With that low compression, you definitely don't want anything too lumpy. I would say no more than 215 degrees duration (@ 0.050) and 0.450 lift on intake OR exhaust.
PS -- What is a "stall converter"?
Old Apr 25, 2015 | 12:43 PM
captjim's Avatar
215 @ .050 is way too much for an 8 to 1 350 with sock heads and manifolds. I was also going to suggest the Voodoo cam that DoubleV did. 60800
http://www.lunatipower.com/Product.aspx?id=1720
I think by "stall converter" he means the stock converter with factory stall speed.
But, with your restrictions (stock manifolds, heads, etc) do not expect a lot, maybe 15-20 ft/lbs at most.
Old Apr 25, 2015 | 05:41 PM
That's probably it.
Also, I did say "no more than". I don't think 215 degrees would be WAY too much, but agree less would probably be better. That Lunati sounds pretty good.
Old Apr 27, 2015 | 08:46 AM
wcourt3010's Avatar
i put the next cam up from that one in my 350 with #8 heads, and i did not "wake up" my 350 but it the car drives nice. i have to swap out my rear gears for something better, i should see a difference there. go from 2:73 to the 3:08 or the 3:21 or whatever the numbers are.
Old Apr 27, 2015 | 09:20 AM
Octania's Avatar
"Stall Converter"
That which converts stall.
change from horse stall to cow stall for example.
Agricultural term.
I guess.
Somewhere along the line "(high stall) [speed] converter" lost the "high" or "low" or other descriptor and became "stall converter"
Much like the fabled "3/4 race cam" from the halcyon days of yore. No one knows.
Old Apr 27, 2015 | 10:06 AM
So my stall converter needs repaired.
4door!cutlass
Mar 23, 2014 09:48 AM
ah64pilot
Nov 12, 2012 09:55 AM
navvet
Mar 11, 2012 06:02 AM
HAFROD
Apr 24, 2008 03:12 AM
