what are the main things i need to do to wake up my 455.
Old Mar 23, 2014 | 03:40 AM
4door!cutlass's Avatar
Being that i'm new to the game,i need your help.my goal is to get 500 horsepower out of my 455 to play with it in the street .its a 86 4door cutlass,455 with g heads,out of a 71 delta 88 .everything stock but a mild cam upgrade and the moter is bored over 40 ,that was done before i got it.
Still has the v-6 rear.
So what is the main things i need to get this thing smoking!!.
Old Mar 23, 2014 | 04:18 AM
Stevec's Avatar
Cam,10:1 compression,edelbrock cylinder heads, 800-850 cfm carb, air gap intake and headers. A reputable machine shop and you'll need some $$$! Goin fast in a olds is not cheap!
There are a few guys on this site who can help you out!
Old Mar 23, 2014 | 04:28 AM
76olds's Avatar
Hookers under Hood
Wow... 500 HP in an 86 4 door, I would strengthen that car up before throwing that amount of HP and torque at it.
Old Mar 23, 2014 | 04:33 AM
Stevec's Avatar
That v6 rear will be the first thing scattered all over the road! What do you have for a transmission?
Old Mar 23, 2014 | 04:49 AM
jensenracing77's Avatar
Are you new to Oldsmobiles or engines? First thing is to not listen to chevy guys that toss around HP numbers. Oldsmobiles build great torque. In a G body you will have a real fast car with a 455 and not need 500 HP. You can get 500 torque and 400 HP VERY easy with a 455 and in a G body that will scream for the street. If you want 500 HP.... like others said, It is going to cost more money.
Old Mar 23, 2014 | 05:17 AM
Its a 400 trans,yea I'm trying to decide on what size rear to put behid it, and that's a very good point about strength .i had planed on upgrading the springs and shocks,i already upgraded the universal joint but what is the main things i need to upgrade to be able to handle the horsepower and doing doenuts,lol.
and thanks guys for the input,i was surprised to get responses so soon!.
also i wanted to say,i still want to be able to drive the car on the freeway,so from my investigation,373 gears would be too much.how about 342or355 gears .
Old Mar 23, 2014 | 05:30 AM
76olds's Avatar
Hookers under Hood
I'd start by welding the rear doors shut LOL. Others will chime in on your goals... good luck with your build.
Old Mar 23, 2014 | 05:32 AM
Yes I'm totally new to olds and engines.its become an obsession.
Old Mar 23, 2014 | 07:11 AM
Welcome to the site, post some pictures when you get a chance. As the others said 400 hp is an easier goal to attain with a lot of torque. You can search the site for a history of build threads to get an idea of what others have done for their builds. Here is a calculator that one of the other members posted a while back for gear ratios.
http://www.angelfire.com/fl/procrastination/rear.html
Old Mar 23, 2014 | 07:37 AM
Ok,thanks,now i have a better understandling.so i agree 400 horsepower is a better goal but now lets talk about tork.so what is it going to take for me to get more tork.????.
Old Mar 23, 2014 | 07:44 AM
76olds's Avatar
Hookers under Hood
The old saying is... Tell them how much $$$ you want to spend and they will tell you how fast you can go with your 86 4door.
Old Mar 23, 2014 | 09:48 AM
For starters, go to Google and type in 455 oldsmobile engine build.
marklt
Apr 27, 2015 10:06 AM
ah64pilot
Nov 12, 2012 09:55 AM
navvet
Mar 11, 2012 06:02 AM
HAFROD
Apr 24, 2008 03:12 AM
