Olds heads
Old Jul 29, 2009 | 05:28 AM
boese1978's Avatar
Olds heads
Hi,
I came across a set of Olds heads for 20$, needless to say I snapped them up. I was told they were from a '68 350. How can I ID them to be sure? My plan is to have them rebuilt and then replace the tired ones on my 68 Cutlass ( also will rebuild the short block).
In the same vien, I was reading my Motors Manual and see that 68 350 have a couple different compression ratios listed. Are the differences soley related to the combustion chamber size? and again, is there a fairly simple way to ID which is which?
Any minor performance tips for these heads would be appreciated too!
Thanks!!!
Old Jul 29, 2009 | 05:48 AM
Carnac the Magnificent says,
"What # or lettters do they have on them. Post and someone will shed some light on the subject."
Old Jul 29, 2009 | 05:52 AM
captjim's Avatar
It is very easy, they will have a large number on the corner, in this case if it is a 68 head it should be a "5" Cylinder head volumes were the same, compression ratios were changed by using a different sized dish in the piston.
Old Jul 29, 2009 | 06:44 AM
boese1978's Avatar
Excellent help captjim, thanks! These have a "8" so I suspect they are from a 73-76 ( found a cool website to help in ID'ing)and not a 68. I seethe ones in my car now are "5", is there a way to determine the compression ratio without removing the heads to see the pistons?
Thanks again.
Old Jul 29, 2009 | 07:56 AM
You can do more that "suspect". You can be 100% certain.
I see the ones in my car now are "5", is there a way to determine the compression ratio without removing the heads to see the pistons?
Thanks again.
No, unless you have xray vision or a borescope to look in the spark plug hole at the size of the dish.
Old Jul 29, 2009 | 11:36 AM
captjim's Avatar
To add to Joe's post, the factors determining Cr are the piston dish, depth in the hole, gasket bore and thickness, and cylinder head volume. There is a tiny amount between the piston and the top ring. So, there are several variables. If the engine has never been apart, the Cr should be in the low-mid 8.xx to 1 neighborhood. But, that is just an estimate. Read this if you care to,
http://www.oldspower.com/vb/showthread.php?t=36717
EDIT Obviously, bore and stroke are primary factors, too. In the case of an Olds 350 it is 4.057 x 3.385.
64 CUTLASS KEN
Dec 7, 2020 06:43 AM
QS442
Jun 12, 2014 06:47 PM
olds4life
Dec 25, 2012 12:56 AM
gearheads78
Nov 10, 2009 09:31 PM
DarkStar
Oct 21, 2009 07:35 AM
