Olds engines
Old May 10, 2009 | 07:23 PM
oldman's Avatar
Olds engines
I have two olds engines.One is a olds 403 and is not working.The other is a olds 307 and works but throws white smoke.Can I swap parts from the 403 to the 307 to fix the problem and to add power to it?
Old May 11, 2009 | 06:09 AM
Oldsguy's Avatar
Past Administrator
Not the heads, which may be the culprits of the white smoke. Year, make and model would help out too. Welcome to CO.
Old May 11, 2009 | 07:22 AM
Lady72nRob71's Avatar
Welcome to the site!
What is wrong with the 403?
Fixing it would be the better choice, no matter whats wrong with it...
The 307s have limited potential.
Old May 11, 2009 | 07:23 AM
Yes, you can. Jack up the air cleaner of the 307 and swap everything underneath.
Seriously, it depends. Both motors are small block Olds motors, so much is common, however as noted above, your smoke problems likely require repair to parts that are unique to the 307. It also matters whether the smoke is wispy white (water) or heavy bluish white (oil).
Old May 11, 2009 | 07:41 AM
citcapp's Avatar
Welcome to the site. Are you sure its smoke and not steam. Does excess water drip from the tailpipe when the engine is running. Have you checked to see if the water in your radiator is low. Could be a blown head gasket
Old May 14, 2009 | 01:09 PM
oldman's Avatar
403 and 307 olds info.
403 olds came out of 77 trans am,has 4A heads,block casting # is 557265 4B.The 307 olds casting # is 479OGM5.0LG. Dont know what car it came out of or its year.
Old Jun 20, 2009 | 06:03 PM
csstrux's Avatar
moved this to the appropriate section where it should see some more activity.
mashbaugh
Sep 17, 2012 08:40 AM
MJAKS462
Oct 29, 2010 05:32 AM
olds4life
Jun 19, 2009 07:21 AM
akaed
Aug 1, 2008 07:34 PM
1340
Apr 2, 2006 07:13 PM
