Olds 7A Heads & Harland Sharp S4004 Rockers
Old January 3rd, 2021, 10:20 AM
  #41
Chevy budget Olds powered
coppercutlass's Avatar
I might add I have the same rocker arm studs and my pads are not milled.
coppercutlass is offline
Old January 3rd, 2021, 12:24 PM
  #42
Duh
Duh's Avatar
https://www.summitracing.com/search/...er-in/0-342-in
Duh is offline
Old January 4th, 2021, 02:54 AM
  #43
Nic_The_Cutlass_Guy's Avatar
Originally Posted by coppercutlass
Ok so I'm under 1.5 from center of the roller to the fulcrum area. Like 1.4 best I could measure with the rocker arm on the car and I did it a few ways. Dial caliper and a dress makers measuring tape lol. Of course the measuring tape wouldn't be exact but it backed up my dial caliper measurements. A few pics that may help.
Thank you so much!! Amazing Pictures!!
so i have 1.511 Inches (38.38mm) and you are at 1.4 inches (35.56mm) with these Ford 302 (1.6 Ratio) Rockers.
This is a difference of 2.82 mm / 0.1110236 inches!
uff.. i think these Ford Rockers would fit closer to the center of my valve tips.. whats your opinion?
Nic_The_Cutlass_Guy is offline
Old January 4th, 2021, 02:55 AM
  #44
Same like me (no milled pads)
Old January 5th, 2021, 11:22 AM
  #45
akspeedy's Avatar
I had a similar issue and ended up going with the harland sharp S50026A set up, there is no machine work needed and my factory length pushrods were the correct length. I found it to be the easiest solution.
akspeedy is offline
Old January 5th, 2021, 12:26 PM
  #46
oh thanks for your input!
it try to get in touch with Harlandsharp about this problem.
At the moment we have HA5003, HA5016 and HA50026A as "maybe" possible solutions on the table, if i stay with Harlandsharp Rockers.
Great!
Old January 5th, 2021, 12:43 PM
  #47
akspeedy's Avatar
Great!
the S50026A work with no machine work needed and i believe are rated for at least .500 lift, i have a little more lift than that with my cam and I have had no issues. good luck
akspeedy is offline
Old January 5th, 2021, 01:06 PM
  #48
What typ of Heads are you using ?
do you have any detailed pictures of this installation?
Thank you!!
Old January 5th, 2021, 02:11 PM
  #49
akspeedy's Avatar
Thank you!!
I have 7a heads I don’t know if I have pictures if I can find them I’ll post them
akspeedy is offline
Old January 5th, 2021, 02:16 PM
  #50
akspeedy's Avatar
Unfortunately this is as detailed as I have!
akspeedy is offline
Old January 5th, 2021, 03:06 PM
  #51
This is superb as reverence and helps me & others alot!
So i can start to ask around and maybe i find some measurements of the Fulcrum Center to the Roller Center some where.
Thanks alot!!! Great help too!
danktx
June 2nd, 2018 06:07 AM
Rocketman!442
August 15th, 2016 11:22 AM
cdrod
February 26th, 2016 10:19 PM
72 cutlass455
January 25th, 2010 06:58 AM
Oldwolf
November 17th, 2009 07:48 AM
Quick Reply: Olds 7A Heads & Harland Sharp S4004 Rockers
