olds 350 swap
olds 350 swap
hope this is the right place ..I didn't see a swap specific section, for the obvious reason
first of all i don't know if this is the right forum but here goes
so the BOP patterns on the transmissions
could I possibly bolt a 350 in a 63 grand prix just to tow the barge while i rebuild the 389?
i seem to recall the 63 389 starter is mounted differently (on the block i think)
so does anyone think this is possible ...or should i go to a pontiac forum with this question?
You're better off with a poncho engine if you just want a temp while you rebuild the original. There is just too much to change to make it worth while to drop an olds engine in there just for the time being.
Maybee, the real early pontiacs´s have different bellhousing pattern. I have checked a 63 Poncho 389 block with a BOP TH 350 trans and they have the same boltpattern. The bolt size is UNC 7/ 16 in the block
oldrelics
Non-Olds Engines
June 12th, 2014 07:09 PM
'69CutlassVert'
August 25th, 2011 07:19 AM
