olds 350 swap
Old Jan 28, 2010 | 02:38 AM
mrohler's Avatar
olds 350 swap
hope this is the right place ..I didn't see a swap specific section, for the obvious reason
first of all i don't know if this is the right forum but here goes
so the BOP patterns on the transmissions
could I possibly bolt a 350 in a 63 grand prix just to tow the barge while i rebuild the 389?
i seem to recall the 63 389 starter is mounted differently (on the block i think)
so does anyone think this is possible ...or should i go to a pontiac forum with this question?
Old Jan 28, 2010 | 02:54 AM
svnt442's Avatar
You're better off with a poncho engine if you just want a temp while you rebuild the original. There is just too much to change to make it worth while to drop an olds engine in there just for the time being.
Old Jan 28, 2010 | 02:58 AM
mrohler's Avatar
thank you very much
only asked because i found a 350 really really cheap still going to pick it up
if only I could find the ponch power plants that cheap!
Old Jan 28, 2010 | 01:28 PM
Oldwolf's Avatar
63 Pontiac 389 engine has the starter attached to the transmission housing, at least the automatics. More problems are the converter snug ( Is this english?) in the hydramatic transmission, if its a auto car your talking about. BOP Patter should bee the same but,many different things in this swap.
Old Jan 29, 2010 | 12:27 PM
I think the early Pontiacs use a different bellhousing bolt pattern - it's not the normal BOP.
Old Jan 29, 2010 | 01:48 PM
mrohler's Avatar
That very well could be the case as well.
I just don't know yet, at any rate I know there is some kind of difference that was to be of concern.
Old Jan 31, 2010 | 05:30 AM
Oldwolf's Avatar
Maybee, the real early pontiacs´s have different bellhousing pattern. I have checked a 63 Poncho 389 block with a BOP TH 350 trans and they have the same boltpattern. The bolt size is UNC 7/ 16 in the block
Old Jan 31, 2010 | 05:39 AM
mrohler's Avatar
if it makes any difference ...it does have the slim-jim roto-10
oleary
Jul 19, 2016 09:56 PM
falconsfan
May 14, 2015 05:47 AM
oldrelics
Non-Olds Engines
Jun 12, 2014 07:09 PM
'69CutlassVert'
Aug 25, 2011 07:19 AM
mcutlass1969
Jun 11, 2009 06:27 AM
