olds 350 crank but not start
Old Apr 22, 2017 | 12:13 PM
  #41
crazymathlefou's Avatar
i will buy this :
https://www.summitracing.com/parts/clo-c-3006k
Old Apr 23, 2017 | 07:43 AM
  #42
olds 307 and 403's Avatar
Out of Line, Everytime😉
That timing sets should work. Get this set to seal it back up. https://www.summitracing.com/parts/FEL-CS8171-2 That nylon coated timing set is about the only reason an Olds 350 needs pulled apart after some miles and years. The timing cover can be a pain to put back in, the lower seal will need trimmed on the cover. Hopefully the Edelbrock carb will work OK, many have issues with them. It will no doubt be too rich for that motor.
Old Apr 28, 2017 | 05:11 AM
  #43
I have replaced cam sprokle, crank sprokle and timing chain.
Mark on crank sprokle is on up. Do you know if the cam sprokle mark must be at down or up?
Best regards from france
Old Apr 28, 2017 | 05:17 AM
  #44
Cam mark up = TDC on #1 cylinder.
Cam mark down = TDC on #6 cylinder.
Old Apr 29, 2017 | 04:28 AM
  #45
that works ! thousands of thanks for you help guys !!
Old Apr 29, 2017 | 04:34 AM
  #46
Well done
Old Apr 29, 2017 | 05:25 AM
  #47
Sporty45's Avatar
Old May 1, 2017 | 12:04 AM
  #48
Ha ha. Bravo!
Old May 1, 2017 | 12:58 PM
  #49
ROCKETMAN269V's Avatar
He would be wise to pull the oil pan to clean out all of the debris that will get drawn into the oil pump pick-up screen. I've seen it happen a number of times.
Old May 1, 2017 | 08:06 PM
  #50
Before he puts it back together, he should drive out the broken oil fill tube while it is easy to access.
Old May 1, 2017 | 09:46 PM
  #51
VI Cutty's Avatar
Felicitations! Bon travail
Old May 2, 2017 | 06:17 AM
  #52
Oil fill tubes are easily removed by tapping all around with a rubber mallet.
Old May 2, 2017 | 11:32 AM
  #53
I have never tried removing one but his is broken off nearly flush.
Old May 2, 2017 | 11:46 AM
  #54
Access to the bottom of the oil fill tube is limited at best. I'd suggest a bearing puller hook on a slide hammer from the top.
At first I though you were talking about the dipstick tube. How the heck do you even break the oil fill tube like that???
Old May 2, 2017 | 11:49 AM
  #55
I didn't notice that it was broken off flush.
Old May 2, 2017 | 06:41 PM
  #56
I'm curious as well.
Old May 3, 2017 | 04:55 AM
  #57
time for rebuilding all now.
for checking if oil pan are dirty, i'll relive it.
i notice the water pump have only one hose out.
the water tank is only plugged on the radiator. he is empty.
do you know if the water tank is usefull ?
Old May 7, 2017 | 10:43 AM
  #58
according to another seville owner, there is only one out on water pump.
Now, engine start, rpm are lower then engine stop.
Tom442
Mar 20, 2022 06:20 PM
Gmcdually
Jul 14, 2016 06:32 PM
jensenracing77
May 29, 2015 01:20 PM
garyfoust
Nov 25, 2012 04:32 PM
rrielley
Sep 1, 2008 03:00 AM
