Old Head Gasket Removal
Old Apr 20, 2013 | 11:31 AM
my71olds's Avatar
Hello:
The heads have been pulled and rebuild on a 71 olds 350. There is some old head gasket on the block. Using gasket remover now but is there a better way to get this off?
Old Apr 20, 2013 | 01:39 PM
Sure: 2" ScotchBrite pad on a hand drill or die grinder.
Old Apr 21, 2013 | 07:25 AM
2blu442's Avatar
Are you bolting the heads back on without tearing down the rest of the engine? If so be careful that you don't get particles you cut/scrape off down the cylinder bores. This could be grit that would damage the bores.
John
rkk69olds
Oct 23, 2013 04:03 PM
aussiemobile
Feb 15, 2013 07:31 AM
harry k
Nov 21, 2012 08:54 AM
dallasite21
Jun 20, 2010 05:37 AM
Sixoh
Aug 8, 2006 05:11 AM
