OIL Pump
Old Jan 10, 2009 | 01:37 PM
mp71conv's Avatar
OIL Pump
I am Rebuild my 71 olds 350 now and was wondering if there is a gasket for the oil pump to the main bearing?
Old Jan 10, 2009 | 01:42 PM
dan2286's Avatar
Yes. It should be in the gasket kit.
Old Jan 10, 2009 | 01:48 PM
f-85's Avatar
Actually no there isnt. No gasket from the pump to the cap. At least not on a 69 455. ill look it up now.
Old Jan 10, 2009 | 01:52 PM
mp71conv's Avatar
I thought there might be, but there is not one in the kit and I have been looking it up all over and have just found the gasket for the cover.
Old Jan 10, 2009 | 01:54 PM
f-85's Avatar
I had the same thought when i put my pump in. But no no gasket. Not even in the 71 350. So your good to go!
Old Jan 10, 2009 | 03:05 PM
dan2286's Avatar
Thats odd, I had one in the gasket kit for my '77 350.
Old Jan 10, 2009 | 03:47 PM
f-85's Avatar
IDK When i did mine thats how it was. Then i did some research for the 71 350 and found nothing, other then the gasket for the oil pump rebuild thats it.
Old Jan 10, 2009 | 04:09 PM
dan2286's Avatar
What part number did you get?
I got this number on Summit for a 77, and this is all that came up. Of course it does not have a picture, and has a generic description. Maybe they used one for the newer style blocks???
Here is the link for what I found, http://store.summitracing.com/partdetail.asp?autofilter=1∂=FEL-13458&N=700+4294748078+115&autoview=sku
J-(Chicago)'s Avatar
Seasoned beater pilot.
No gasket on the pump to cap to my knowledge.
Buicks had them, but not olds.
Old Jan 10, 2009 | 04:15 PM
f-85's Avatar
Well maybe felpro makes a gasket, but the engines dont cal for one. at least the 71 and down.
Old Jan 10, 2009 | 04:35 PM
dan2286's Avatar
I am not sure what these are. Could they be what I am thinking of?
Does anyone know what those two gaskets are on the left side?
Old Jan 10, 2009 | 04:43 PM
Dan, those are the oil filter adapter gaskets.
The little black oval one is for the oil pump cover, in case you want to pack the pump full of lubricant.
Old Jan 10, 2009 | 04:52 PM
dan2286's Avatar
That must be what I was thinking was used for the oil pump. I was trying to think of what those gaskets were for and I forgot about the oil filter adapter.
Sorry for the confusion.
Old Jan 10, 2009 | 05:55 PM
No sweat.
I mess something up almost everyday. Yesterday, I soaked an old carb body in vinegar to get the rust off. Pulled it out today, and it ate a lot of the plating too.
Live and learn.
Old Jan 10, 2009 | 08:23 PM
ent72olds's Avatar
Registered Luser
Now the carb is "patina'd"! All the rage now , especially for ratrods, of course you knew what you were doing!
Redog
Oct 20, 2015 03:29 PM
sshriber
Mar 22, 2010 06:16 PM
86pontiac
Feb 17, 2010 11:24 AM
72Ctlss
Jun 23, 2009 03:12 PM
