Oil priming a 330
Old May 21, 2022 | 12:46 PM
brianbeez67's Avatar
Oil priming a 330
Fresh rebuilt 330 (the engine shop near south Philly Pa) been sitting for a year in the garage mocking me. Need some help with oil priming the engine. I know there is some kinda tool I can purchase to rotate the oil pump.
Any help would be great. Thanks Brian
Old May 21, 2022 | 02:55 PM
olds 307 and 403's Avatar
Out of Line, Everytime😉
Something like this rotated counter clockwise should trick.
https://www.google.com/url?sa=t&sour...4CdguFG_DZ7a_J
Old May 21, 2022 | 03:07 PM
A 5/16 socket secured to a long extension works also.
Old May 21, 2022 | 04:15 PM
edzolz's Avatar
But make sure the socket fits very snugly to the extension, it can slip into the oil pan if it comes off.
Old May 21, 2022 | 04:42 PM
Sugar Bear's Avatar
^^^Good advice^^^
If you use the socket method tape the extension and socket together. Also look in the distributor hole to confirm the galley plug with an orifice was installed. The issue is two-fold, was a galley plug installed and whether or not it is the correct one.
Good luck!!!
Old May 22, 2022 | 05:43 AM
Or for half the price, get a Ford 351 priming tool.
Amazon Amazon
Old May 22, 2022 | 06:50 AM
BackInTheGame's Avatar
https://www.amazon.com/Ford-16-Inch-.../dp/B00ANFNM2U
^^^^ This is what I did for my 400 that sat for nearly five years. Works like a charm and you don't have to worry about anything being dropped into the block/pan.
Coastie
Feb 29, 2020 03:54 AM
Conrad67
Nov 3, 2018 01:04 PM
stanzaschance
Jul 27, 2015 03:23 PM
ron3083
May 27, 2015 08:06 PM
oldstata
Mar 22, 2015 09:45 AM
