Oil pressure question
Old Jul 9, 2020 | 10:12 AM
lrios's Avatar
What is normal operating oil pressure for a '69 350? At idle I'm at 40psi and at cruising speed around 2200rpm my pressure is reading around 50psi and as high as 60psi under acceleration. Is this normal? Seems a little high to me but new to SBO engines.
Old Jul 9, 2020 | 11:51 AM
gs72's Avatar
72Cutlass S
Sounds about right to me.
Old Jul 9, 2020 | 11:58 AM
lrios's Avatar
Thanks. Getting a lot of feedback from a FB group all saying the same thing.
Old Jul 9, 2020 | 12:07 PM
droldsmorland's Avatar
CH3NO2 LEARN IT BURN IT
40-60PSI sounds great. Is 40 your warm idle PSI? If so that's fine
Curious, what type and weight of oil are you using?
I recommend using top quality oil filters...WIX, NAPA Gold, Baldwin.
Use high Zinc oil or zinc additive and add some ProLong after break-in in if its a fresh rebuild.
Old Jul 9, 2020 | 12:55 PM
lrios's Avatar
I'm pretty much at 40 from turnover regardless of engine temp. Haven't fired her up in cold weather though. I am running 10w30 with a wix filter. Only mods I'm aware of are edelbrock rpm intake and 1406 carb, long headers(unknown brand), hei distributor(gray cap/unknown), accel coil and a jegs 2.5" exhaust.
Old Jul 9, 2020 | 01:39 PM
That's about the same as my engine.
Old Jul 9, 2020 | 01:44 PM
That's great oil pressure for a healthy engine.
Old Jul 10, 2020 | 12:10 PM
Agreed, no cause for concern at all.
Old Jul 10, 2020 | 01:10 PM
lrios's Avatar
Thanks everyone for the replies. Feeling good driving now.
May 6, 2026 07:30 PM
Bluedane
Jan 30, 2015 05:40 AM
69CutlassAlex
Oct 24, 2011 04:55 PM
Thomas Simcich
Oct 13, 2010 11:28 AM
airhead6969
Aug 10, 2006 11:00 AM
