Oil pressure light
Old Sep 16, 2012 | 05:37 AM
runner66's Avatar
Oil pressure light
Good morning all. The oil pressure light in my 70 CS recently came on, in spite of having no shortage of engine oil. In running through the possible scenarios, is it likely that the sending switch is faulty and/or that the oil pump is in need of replacement? The question gives this away, but I'm not particularly handy under the hood and want to be prepared when I bring the car into my local mechanic (central NJ).
Many thanks.
Old Sep 16, 2012 | 06:34 AM
1970cs's Avatar
Lansing built
You need to plumb in a mechanical guage to verify what pressures are!
30-45 psi @1500 rpm this can vary on tightness of engine and weight of oil. Pat
http://wildaboutcarsonline.com/membe...ss_Supreme.pdf
Old Sep 16, 2012 | 06:53 AM
runner66's Avatar
Pat:
Thanks very much for your reply and the helpful link.
Best,
Tim
Old Sep 16, 2012 | 08:49 AM
Also check your oil for fuel contamination due to a failed fuel pump.
Old Sep 16, 2012 | 09:07 AM
Octania's Avatar
Verify pressure or lack thereof with a mechanical gage in the port at the front of the engine, just to the left of the block ID, fwd of the intake, and aft of the timing cover. Remove the op sending unit [1-1/16" socket?] and install 1/8 NPT fittings to your gage.
I can haz oil pressure = replace the sender
I can haz no oil pressure = dig into the engine. Probably nylon timing teeth and/or strings of silicone in the oil pump pickup, but other things may also cause this. Drop the oil pan first, or go ahead and step into Mightaswell City and pull the motor.....
72Blazerod
Jan 1, 2015 10:04 AM
455man
Aug 25, 2014 06:14 AM
foreverolds
Dec 1, 2012 07:07 PM
Redog
Jul 20, 2011 04:10 PM
