Oil not reaching rockers
Just had my 69 350 rebuilt and went to prime the oil pump and I'm not getting any oil to the rockers. Just to the lifters. Using a Drill ? Maybe need a stronger one ?
We're the oil galley plugs installed AND the correct ones with holes in them for the timing chain and the distributor gear?
Getting oil to the rockers can be tough but if the plugs were left out it may never happen. If the wrong plugs were put in it will cause oil starvation.
Good luck!!!!
Good luck!!!!
Good luck!!!!
Good luck!!!!
What RPM does your drill turn ? You might need a faster one. Is oil draining from all lifters ? What brand lifters are you using ? Is the smaller area around the lifters protruding out the top or bottom ?
[QUOTE=OLDSter Ralph;1240764]What RPM does your drill turn ? You might need a faster one. Is oil draining from all lifters ? What brand lifters are you using ? Is the smaller area around the lifters protruding out the top or bottom ?
its coming out the top and I'm using a small drill I just read onreade it could take anywhere from 20 - 30 mins using a drill but I have to get a bigger drill.
[QUOTE=Kyron219;1240767]
Are you running the drill counter clockwise? That would reverse to normal drilling.
